How long would it take a machine shop to set up 4 wheels on their large scale industrial lathe, taking the correct amount off and not risking upsetting the balance of the wheel in any way.
I'd imaging it takes a decent amount of time to do considering you're grinding inside the area you would normally mount it with... So it's gotta be done using clamps around the outside of the wheel.
If each wheel was completely done in 15 minutes (wouldn't be), that's only $80 an hour for precision work on a machine worth many thousands of dollars.
now feel sorry for the guy and will pay him extra.
freedom=your welcome etc. etc. etc
cos Afghanistan and Iraq were totally invading Australia...
my freedom was set the minure I was born a white male in a 1st world country
lol.
the kosovans and the northern irish were not invading either chum. dont forget them!
neither where the Somalians or the kenyans for that matter!
or those Indonesians that had there houses destroyed by a tsunami, or the haitians whose country was destroyed by an earthquake.
no your right mate. should have just been a chef aye.
btw the freedom thing was a piss take, but since you had a bite.....
My freedom was when I was 18 and finally allowed to do what I want, legally abiding by law. And not breaking any rules and doing what is socially perceived as acceptable..
I feel so free
I feel so free
your welcome.
I feel so free
My freedom arrived the day I forgot to wear underpants
And I'm freeeee
I'm freeee ballin'
like i said ill give it a chop my self. i know an hour of my time aint worth 80 bucks. being a veteran an all, all im fit for is shinin shoes and saluting the flag.
ill get em balanced after, if it dont work ill get he other done properly.
thanks for your input victoria.
as flamin mongrely as usual.
That was literally just on the radio? Coincident? Conspiracy? Illuminati is watching
This is the core of the issue... You don't think it's worth $80/hour to do, however for a skilled machinist in a shop dedicated to tasks like this it is...
They've got to pay Wages, overheads, Rent, Cost of Equipment and Consumables, Superannuation, Taxes, Power, Gas, Advertising and a skinny philo called mikeymike to sweep the floors. They're a business, if that can make a small profit after that they're doing well.
This is why I DIY as many things as I can, only going to specialists if its something that I can't (or it isn't cost effective for me) learn to do myself using my own tools.
You're a tool
lol.
too easy platz...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
