standard 33 GTR seat failure.
came into a left 270 and as I smashed it into 1st and ripped the handbrake the seatback let go and I ended up in the back
LOL!
that happened in a VL i was driving. didnt rip the handbrake, just turned a corner and planted it
the worst by far was that one when it BUCKETED down and that guy was there in the elfin clubman v8...
Poor dude had the worst day... freezing in the morning with no roof (he wore his helmet on the drive up) and then flooded on the way home (was using said helmet to pail water out whilst driving)
I was running 235 NT05's and driving at ~80 tops on the fwy as the car would just aquaplane into other lanes randomly...
yeah after sau nats in shep (the best one, when i finally met the one they call dezz, and jonoe and i realised that birds sleeps like hes dead)
driving back home with -6deg camber was sketchy as f**k.
had a mate who knows what hes doing when it comes to wiring come and help tuck the headlight wires, relocate the front body harness.
f**k me.
nissan really couldnt be f**ked with these cars..
that was the guy that was on R888 semi's and found out there was no drain plug in the car...apparently drilled one when he got home.
think i recall driving behind you and seeing your car all over the place
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
