Are they the famous indestructible headphones?
sure are
Track on the right deck is The Generator "where are you now?" (Moonman mix)
Must have been a morning set
I actually just got given a couple this morning from some early 2000's break in warehouse parties. I can link you if you want.
#illegalactivity
#hardcore
#oldtimeyrave
#nocareerinpoliticts
What happens when security rocks up and the crowd disperses? DJ makes a run for it too, leaving his $$$$ decks behind or...wait for it...stays to face the music?
It's never the dj's equipment unless he is running the party and on a budget. It's usually hired a long with the system.
It didnt normally matter as they were abandoned anyway
courier/taxi driver, roads more,dangerous than your average war zone...20$ an hour on a good day, no super, no holidays, no every second Friday holiday...a shitty old 400,000km + company car
Dont give me your sob story
A courier isn't exactly qualified or skilled... Nothing against them, we can't all be brain surgeons, but it's unskilled work nonetheless.
Qualified line cook
4 year apprenticeship
$20/h
Working nights and weekends
But the worst part is that troubling thought in the back of your mind that you just cant get over. That constant stomach churning and deetp sadness you feel for those poor electricians.
I don't get the point of everyone telling me about all these hard and underpaid occupations/careers. They're underpaid, they choose to do nothing about it and cop it while their boss/employer takes home the cash. Unions allow workers to not just be bent over and f**ked in the ass by greedy employers and builders in my industry. They also put a big focus on safety, for real not just the shit you guys seem to think you know about, without having actually worked in construction.
Uni student
4 years full time
-$10 an hour
No job guaranteed at the end of this
Come to me when you pay to work fgts
My mate did full time uni to be a high school teacher... He worked pretty much the same hours I did at the time. Half day of classes on a Wednesday and optional tutorial or lecture or something on one other day of the week... Hardly a gruelling task.
Surely not as grueling a task as running cables provided it's safe, as in not to hot or to wet or to windy or after 4.00pm or every second Monday!
amiright?
pls dont bash me i just like to stir the pot
Edited by alr33x
  • Like 1
Still paying to learn
The only reason undergraduates (except arts students, they don't count) enrol in uni is the prospect of a good job down the line or entering an industry that requires it
It's a sacrifice up front and a shit one at that, made worthwhile if you see a good job from it but plenty don't and come out the other end with a low interest debt
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
