Ya see the kids they listen to the rap music which gives them the brain damage with the hippin and the hoppin and the bippin and the boppin...so they don't know what the jazz...is all about
  • Like 3
Applicable in the way I presented it, i.e solely a comparison of how the price is increasing exponentially.
No one is suggesting that a 600sq block in brighton is an average house price
Fuark, imagine
Would be the best lad pad of all time
can just imagine Dezz waking up early and mistaking one of your loud jackets for his high vis and being laughed off site
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
