  • Replies 283
haha yeah maybe with another part of hte car, but if hte gearbox goes i can't see it causing you to cause any other damage?
Regardless I agree with zahos, if your taking it on track, straining it etc.. then sure, but for a daily driver VMX80 is a very good oil...
Hmm to summarise because I'm lazy. Good point about a gearbox being not worth 20-30-40k however I once blew a gearbox at just under 200km/h and I can tell you that I'm lucky to be here.
Had a gear come up through the floor pan, and miss me, but still. It sheared one of my exhaust pipes off causing the back section to drop straight into the ground lifting my back wheels into the air at about 180, splashed very hot gear oil on my leg and also on the exhaust causing the cabin to fill with acrid smoke so i could barely see where i could barely point the car anyway.
Luckily the driveshaft was held up by the handbrake cable and didn't drop down too. Instant chop job otherwise.
Apart from that freak occurance, I own a Skyline so I can drive hard and that's what I do. Witness the fact that I rarely get 300kms from a tank of fuel. I feel the car deserves to be looked after.
To be honest, it surprises me how many Skyline owners drive like grannies most of the time.
that is freaky!
what car was it in....
anyhow, I ain't no granny driver myself, I do like to reach the speed limit in a very short period of time, but that still doesn't tell me that the oil I use isn't good enough, hence why i still can't justify the cost....
If I were reaching speeds of 200km, then I would consider moving to a better product, but i still think that there are no gains for me in particular at the moment.
are we talking about adding roil to redline here?
Yep... once i get some redline i plan to test it using a friction brake test machine... and see where it cracks... then add roil.. and do the same thing... i'll post some results then justify whether its worth using redline and roil, or just some top motul gearbox oil and roil... in my gemi rally car i plan to use redline and roil, though for a daily driver i expect the results to be exactly the same with roil and motul.. so like its been said... daily driver, redline ain't really worth it.. especially if your gonna use roil.....
On a serious note (not being sarcastic or trying to rub it in)... has anybody who's tried roil and bought it off me got anything bad to say... ie, more fuel cause of more boost etc... or something similar... i'm open to critisism..
cheers
Zahos..
I think the main reason people opt to use Redline is that there are ALOT of skylines out there with crunchy gearboxes.
And on EVERY occasion where redline lightweight shockproof was used, the crunchyness went away.
In my r32, 2nd gear would crunch (going 1st to 2nd) at anything above 5000rpm if shifting at normal shift speeds.
tried some synthetic penrite stuff, still the same.
I bought the redline oil and after about 50km of driving, the crunch never came back.
to me, $100 on 3.8L of Redline oil was a great investment. Considering that the gearbox oil doesn't get changed every 5000kms like the engine oil does which tends to cost $50 at least.
Anyway, in my current car (S14) the gearbox is the best I've ever owned, and I will not bother using redline as I don't see the need.
Who knows. It was an HX by the way. I mean who knows whast the previous 14 owners did to that thing. Apart from that I guess the old M21 is not the most robust piece of equipment. Was originally designed to go behind a 1600 4 pot and I had a warmed up 308 redlining in 4th.
I guess my point was only that you should look after your machinery as best you can cos it can kill you.
abobob: thats nutz!!! i hope that doesn't happen to me :) but would redline of prevented that?
Its actually not that uncommon. Same goes for flywheels when they let go.
Edit: To clarrify, its not uncommon when a g/box decides to die that cogs start sheering bits off. However (and luckily) they don't let go that often like that.
LW.
Zahos..
Fair enough, it it's tried and tested with extra crunchy gearboxes, then why not. For me the crunch was only apparent going from 2nd -> 4th, and it wasn't that bad. If I went 3rd -> 4th it never happened...
If I gunned it off the line, up to 60km/h in 1st, then straight to fourth it happened every time.
Now that the roil has done over 700km in my gearbox I cannot get it to crunch at all..... Notchyness has been reduced, and the gears go in much smoother now, and the car feels great.
I will definately using this stuff again....
Zahos
Zahos
Awesome... :)
Seen this thread again, I don't bother looking for old threads much.
as for take a look around at a few skyline website and pages around the internet, even the factory specs as well.
I must say though I'm quite shocked and very disapointed if that is the real life changing speeds of the Skyline box, so much so, I'd call it a pathic gearbox at best, as my 1981 car could flog it without any problems or questions needed of it.
It wouldn't surprise me, if 3-cyclinder echo's were chewing you up at the lights.
No wonder you need roil your car is struttering and craping it self, because it's in the wrong bloody gear at a slow speed.
How many people have posted about dodgy gearboxes here? 5 maybe? Haven't counted, don't care.
And how many registered users are there to this website? 4000 roughly.
I'm presuming that you're generally bagging Skylines here because it's a bit hard to tell since you can't spell and you write sentences that make no sense.
You drive a 1981 "car" because that's all you can afford. Get some education and a job.
:(:):rofl: :rofl: :rofl:
You are a goose! :usuck: :usuck:
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
