Here's a copy of the description of the car...
1988 Nissan Cefiro *modified* - it is a rare heavily modified Cefiro which has been fitted with a RB26DETT from an R33 GTR
2.6L twin turbo (RB26DETT)
5 speed manual
113,000 km's
black
Vertex style body kit
18" alloy wheels
lowered suspension
aftermarket exhaust
aftermarket air filters
tinted windows
many other aftermarket parts
excellent condition all round
Coz its 1988 he can get it into the country right now. As we speak he is signing the contract with J-Spec Imports to make it his.
So get off the streets people, narkeh's bought a ball tearer... oh and he can finally beat Josie's (his gf) car :)
Pics follow:
  • Replies 119
lol to save munkeh from being a plugger... or is that tugger?
yes i am getting it... not confirmed yet i still need a grand by tomorow... damn things just pop up at the worst time :)
bah, a new front bar, new set of rims, new back bar n anything else he can scratch maim and back into lol.
Maybe a new driveway is in order and new airbag suspension... now that would be pimpin...
and ash, i cbf linkin direct to the for sale page hence the link to the site, i found the link n fixed it up... sheesh.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
