Couple of Shots of my GTR from Eastern Creek North Circuit on Sunday last week.
Managed a 1.18.196, which is my first time ever at Eastern Creek and my first time on the track in the GTR.
Suffered major brake fade and I boiled my brake fluid - Braided lines and racing fluid + new disks and pads ordered!!
Also had my coolant overflow tank boil..Hopefully isn't to much of a fix!
Heres the incar video - about 10 minutes in it goes side-by-side when my mate arrived with a second camera.
6 min 50 second see me nearly lose it at turn 2 :D
  • Replies 150
Will hopefully have the car ready for the SAU Nationals and maybe a day or two at Winton before. In the meantime the only track work I have done this year has been in hire cars...but it has eaten most of my finances but well worth it
La Source
Eau Rouge
From the Skyline Nats
bit of tyre deflection, interesting as the sidewalls on the FZ's are so stiff
wish it was the real one behind me, but cool none the less. :)
  • 1 month later...
Had the Ararat hill climb today here's few pics and vid I found on YouTube.
There was 2 r32 gtrs there and r32 gtst my one (purple) and a mates (black one)
I got 2nd in my class 2001-3000cc with a best run of 51.01
1st run 1.02.25
2nd 1min flat
3rd 56.27
4th 56.28
Day two
1st run 56 flat
2nd 55.45
3rd 54.23
4th 52.02
5th 51.01 (best)
Edited by mr turbo
