69 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Most of you would know Baron and myself know the crew at TengaEgg.com quite well, but what you may not know is I'm also a Top 10 client at Tug Toner (Baron is #3)..... Here's a vid if you're unfamiliar.
http://www.youtube.com/watch?v=POXMAiLZhOg
the barron would have the knob of that is his mouth when using it
great idea for the winning WANKR
  • Replies 138
The Luke Youlden Understeer of fail award.
The Quade Cooper Award for services to New Zealand sport.
The Sebastian Bourdais award for the biggest fkwit who happens to share his name with another fkwit.
The Graeme Bailey award for best transformation from chicken choker to legend.
The Niki Lauda award for best flamage.
Oh and can I enter my Chev Corvair if the fitment is aggressive enough?
We need a trophy for the fastest fwd car with chrome front / stock rear wheels and vice versa for rwd. AWD vehicles can have 2 unmatched pairs to be included.
Bonus points if chrome wheels are over 45kg each
Not driving your own vehicle should incur a 1 minute per lap penalty.
  • 5 weeks later...
anyone who has been to a fatz drift day will attest to skidz being had
You can't have drift though, that would be copying Drift Matsuri!
You gotta make it something no-one has ever done before :rolleyes:
How bout the: I blew a head gasket on my rotary award?
The: my car was going to be ready, but couldn't get my parts Bach award...
And: turning my stereo all Tue way up will make it faster award.
Looks like its going to be an awesome event.
Can't wait.
Should have my engine back in time.............
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
