So I finished it...
Went with option c. Nice little pay day. What'd everyone else go with?
damnit, this means i need to do at least 3 playthroughs
saved a man from having his bike stolen. emailed me 100000 shares in his company..very nice of him...then the shares dropped...if i see him again....gonna sticky bomb his hands together.
turns out ive done 2 of the 5 assassination missions.... ill save the other 3 until i have 30 mil plus to invest.
Do these assassin missions make changes to the stock market?
Also went to a couple of those places on the map using the UV light I had to buy from bunning's...$24.50 :/
One was a weed stash... That is it, you don't get anything. Just a random crop lol.
One is a nudist colony
And I did the one where it said to bring $500,000.. I don't think I found the right place.
Was just a dock that you can buy for $250,000..
Edited by ZRBE
Competing companies
  1. CoolBeans – BeanMachine
  2. Burgershot – Up-An-Atom
  3. Clucking Bell – TacoBomb
  4. FlyUS – AirEmu
  5. GoPostal – PostOP
  6. Bilkington – DollarPills
  7. Pisswasser – Logger
  8. MazeBank – BankOfLiberty
  9. Redwood – Debonaire
  10. Slaughter, Slaughter & Slaughter – Bullhead
  11. RadioLosSantos – WorldwideFM
  12. eCola – Raine
I stumbled across a random Weed Farm in the middle of nowhere. Killed e'rybody and stole a $15,000 cash pile. that was it.
I dont carry bulk cash, I just store it on BASQDFWFSD under Ammunation and when I wanna buy something expensive I just trasnfer money over.... almost like what I do in real life *Sims complex*. Would rather save up for the Weed property and just use the income to buy other places, stockmarket online doesnt seem to change much.
I searched the whole area and wasn't even anyone there to kill.. Just weed pants.. No money :(
Some stock tips i got from GtaForums. Am doing another playthrough, and like others am saving the assassination missions til after 'the big job'.
There's also a random event on the freeway on the south/west corner of the map as you go up the coast. His car's broken down and asks for a lift to the airport. If you get him there in time, he'll tell you to invest heavily in 'Tinkle'. Doing so will result in about a 30% return.
Also does anyone know where the guy with the stolen bike is? I'm after his 100k :P
did bike guy today. was Trevor and was coming back from the dock/airport to house.
it's kinda dumb you search the entire ocean floor to find a wreckage and get $12,000, yet help a millionaire get his bike back and gives you a large % of his company... go figure.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
