Hey guys I figured this would interest anyone with an NA, the plan with this car is basically to run a low 14/high 13 second pass while staying completely naturally aspirated so no nitrous/SC/turbo etc and while staying in street trim, so no stripping its guts out. Kinda want to do this just to prove it can be done and to stop people from calling NA cars slow, while they can't compete with a turbo $ for $, they do quite well for what they are.
Here are the Specs:
1990 Nissan 300ZX Z32 "Slicktop"
1430kg
131.4rwkw Dyno tested(previous owner)
Mods:
2.5" Twin UAS Catback Exhaust
2.5" Custom Front Pipes
K&N Pod Filter
Go Fast Bits Underdrive Pulley
F1 Racing "stage 3" 6 button clutch
ECUtalk Consult Display Unit
Bought the car back in 2009 with a 2.5" Custom catback, UDP, Pod & standard clutch for $6200. Was a very nice looking car, atleast to me, and the motor was in perfect nick so i decided to buy it.
From when i first bought it
Not long after i bought it did i have my first go at the dragstrip, here are some photo's
After 5 runs the best i could come up with was a 15.017 @ 97.22MPH :(. My clutch was slipping on anything more then a 2500rpm launch so i had to take off really easy.
About 5 months after that my clutch decided to call it quits, held up well for a stock clutch IMO. After looking for hours i decided on my new clutch, a "Gripforce F1" racing Stage 3 Button Clutch. Oh boy did this take some getting use to for the first day, soon as i picked up the car i got stuck in peakhour traffic! At the drags was chirping 3rd gear at 100KPH :D
A good 1500k's had passed and the clutch had been well worn in i decided to have another crack at the drags, i HAD to get that 14 second pass!
Decided i would take it easy on my first run so i wouldn't stuff up, managed a 14.847 @ 95MPH first try! :happy: What was even funnier was that i had tried to select 4th but had trouble so i let off a bit before the finish line. Ok Second run, was really excited to see what i could get, time to see what it was capable of :D
Timeslip, a 14.6!:
Not Bad considering a lot of first gear was wheelspin and i hit the rev limiter before the finish line! :D
Rear tyres are chinese crap 235/45R17's and were set to 25psi during my runs. After taking my car to Unigroup Engineering, Yavuz concluded that i should be able to run a 14.4 Second pass with a slightly better launch as my 60footer was a pathetic 2.315 seconds.
Mods coming up:
1 Piece Lightweight Tailshaft
Decat Pipes for the track only
AMS Lightweight Pulley Set
Piggyback Ecu of some sort, Either an APEXi SAFC or NIStune.
RE55 Semi Slicks on stock Rims.
Looking to get that 60footer down to 2.1 - 2.0 to see what i can squeeze out of it, no internal work done standard heads & bottom end. I'm fairly confident it will pull a low 14 second pass after work has been done, just have to wait and see, will keep you guys updated! Only things i can imagine would hold me back are my wallet, the clutch and my driving :P
Edited by Super Drager
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/
someone has to say it, might as well be me.
run a 13 second pass = engine out.......
on a serious note, scrap the pulley set and tail shaft and invest in a set of cams. go with a nistune and the semi slicks and you should be able to crack a high 13.
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6082256
If drags are what you want to do then get drag tyres, MT ETs or Toyo TQs, street legal and you should be able to get 1.7-1.8 60 fts, leave the RE55s for track guys.
Do the pulleys, can't hurt, and a piggy back comp and with good tyres and a bit of practise on your take off your nearly there
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6082702
no it won't hurt, but it's probably one of the worst value for money mods you can do
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6083903
The pullies are less than $100 from a mate so i might aswell throw them on, as for cams i want to do this with a standard longblock....i know 13's is a big stretch but a low(er) 14 is something i'd still be happy with for a P plater's car.
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084424
thats a good time, i bet some of the twin turbo standard ones dont do much better,
i wouldnt of thought a button clutch would of been the best choice, you cant really slip it off the line that well can you?
looks like it can already do a high 13 with better launch and reaction time..:whistling::thumbsup:
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084438
yeah button clutchs can be slipped like any other just not as nice to drive daily, reaction time has nothing to do with the ET, its a bad misconception, your time starts once you left the line not how long it takes to get off it :thumbsup: and always drive past the finish line
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084528
Ye my old OS twin plate was a bitch to slip off the line with my dodgy knees lol...made DYI comps hard because 1 run would be a 2.4sec 60' and the next 1.9'
But with enough tyre under the bum you dont need to slip....even with 1500hp :thumbsup:
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084530
Reaction time does affect ET,
this from Willowbank raceway site:
Most newcomers to racing leave when the green light comes on. This will give a reaction time of well over a second. For example, if you pulled a 1.12 reaction time and your opponent ran a .060, you have given away over six tenths start right at the start line. For a more graphic example, with two cars of the same performance running 100 mile an hour in the quarter mile, this .66 wasted at the start represents 96 feet or about 6 car lengths at the finish line!
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084590
That's for heads up racing ala 1st to the finish line. The et doesn't change
You can have an 8 sec and a 17 sec car on the track 17 sec car leaves on the last yellow and the 8 sec car leaves 9 secs later it still runs an 8. Even though the cross the line at the same time. The timer doesn't start until the car leaves the beam
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084592
Yeah a few stock TT's were doing 14.4 sec from what i remember, but there have been a few factory freaks...i know of one that did 13.6 bog standard on good tyres, stock down to the airbox & stock catback. Currently i don't think the car will do a 13, a lower 14 definately possible but a 13 in current trim is a stretch. I only know of one NA 300ZX faster than mine and it had all the work i had and an APEXi SAFC running hankook ventus k104 tyres which was doing 14.54 @ 95MPH with 2.1 60ft. I figured all NA drivers would appreciate what i'm trying to do :P. The button clutch can be slipped but its not something i like doing to it, but for some odd reason i prefer driving it over a full face clutch.
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084612
so if what your saying is right then the one on the right is a 6 second car
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6084646
WTF are you smoking?
Your reaction time is the time it takes from when the green light lights up, and when you break the first beam.
Your reaction time, is all about how QUICKLY you react to the green coming on. If you had come to the SAU NSW drag day we held not long back, Sydney Dragway officials even explained this.
What can quite majorly effect your ET is your 60 Foot time. This is the time it takes for you to travel the first 60 feet of the track. 0.1 of a saving here can be 0.2 of a saving at the top end of the track.
For your ET, your reaction time means NOTHING.
https://www.sau.com.au/forums/topic/381349-the-road-to-13s/#findComment-6085138
    • Spotted in Adelaide last week.... mine! New to me two weeks ago.. love it!
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
