  • Replies 886
No if I pressurize the system with a compressor the only leak is the tappet cover breather. Air would be going past the piston rings and or through the other breather that's hooked to the plenum and coming back through. What exactly do you want to see?
Air shouldn't be going past the piston rings..
You've Got some serious issues.
And when runnin that my boost, why the hell aren't you running a proper electronic boost controller?
Skimping on one of the most critical parts?
I was only going to run what the wastgate actuator would push originally. That's why I haven't got a boost control yet, when I get it holding boost il buy another electronic controller.
Focus on the air leaking with the pressure test, I just run off the actuator and mine runs very well. The lack of an electronic boost controller is definitely not the issue here.
Can you describe the steps you use to peform the pressure test?
I ran 19PSI through a simple manual boost controller and it holds extremely flat through the rev range. Do you really think the cost of an electronic boost controller is worth it?
Have you tried wiring it shut and very carefully driving to see if you can hit 20 psi higher in the rev range? I thought they might have done that on the dyno
Have you tried a different actuator yet?
Simple test if you like, its a stupid one, a dangerous one but at least you will know where you stand.
Disconnect the air feed to the actuator and block the hose. Run the car and CAREFULLY using your foot on the accelerator to control boost and see what happens. This is dangerous stuff as the car will boost as much as the turbo can so it is all up to you to control the boost with your foot. If you see boost rise to 22psi slowly back your foot off and see if you can maintain 22psi. If it keeps rising back off. Your boost graph shows fall off as soon as you hit 22psi so in theory if there is a boost leak, the moment you hit 22psi will create enough pressure to give you this big drop you are having.
I think it might be safe to say that if your car powers past 22psi of boost, say you hit 25psi for example, at 4krpm, then I would say you don't have a leak. More pressure will create a drop in boost if there is a hole somewhere. If you find your self having to mash the accelerator heaps to control the boost then you may have a boost leak.
Seriously though, boost leaks.... You should hear the damn thing.
XR6 will out do you at the lights with a turbo which comes on at 3600rpm, its what happens after that that really matters lol.
I don't like continuously feeding air to the intake when doing a pressure test. Does your pressure tester have a gauge attached to it? Mine was a home made piece, no gauge but there was no need. As soon as I put air in, I heard my leaks, fixed them up and bam no more leaks.
IF you don't hear the leak, its more likely than not that DON'T HAVE A LEAK.
Edited by SargeRX8
I haven't got a different actuator yet, il try the no boost line test again, last time I didn't have much empty road so I mashed it to 30psi and backed off because of traffic.
It was a non turbo xr6 from about 60km up.
My tester has a gauge in it. I made it at work.
3mm of preload
As others are saying, if you can tighten the preload. If you made 30psi clearly you do not have a leak. If you have a leak which only gives way at 22psi, it will definitely give way at 30psi very quickly. Dude get a different actuator and be done with it. I am almost CERTAIN it is the actuator spring.
Leaning towards this also...
However, if the losing all power after 5 minutes thing is still an issue, that doesn't seem like an actuator symptom. That sounds more like a restriction of some sort causing heat soak.
I think the next step has to be trying a new actuator. If that is ruled put then you can start thinking of other possible causes, but right now it seems like the most probable cause.
Edited by Hanaldo
Try a different actuator for sure, as for the loosing all power are you running a standard ecu with nistune? If so is it going to knock maps.
Copy your main fuel and timing maps over to your knock maps, pull a few degrees from the knock map and add a touch fuel to fueling map(For alittle added safty)
Now see if the loosing all power is less harsh. Then retune.
There is deffinately tune issues, the change over from vac to boost is rough. And heat soak make it feel very dead after a few minutes.
It's not possible to create more preload on the shaft, but I could just put washers in to pull the actuator back.
I don't have the password for the nistune so I can't touch it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
