  • Replies 886
Can you confirm a couple of things...
When you pressure test the system, u remove the afm and put in ur test fitting. That means ur intake pipe is in the pressure system, yet has non pressure areas being compressed. Ie your bov pipe and presumably the breather hoses that go from the ex rocker to the intake pipe, yes?
To rule that out please do the test on the system post turbo instead of pre, and make sure ur motor is on TDC. Then work ur way thru to see where its leaking, work forwards... So from there go to ur cooler entry, cooler exit, crossover pipe, throttle body. Work forward until u track how far the leak is into the system.
Ur breather shouldn't need ur finger put over the gromit, that means ur pressurizing ur sump... Obviously from the ex rocker breather via the intake. Otherwise ur PVC is ficked too. Test this before anything else.. Then test the guys infinite boost (blocked actuator) theory and see if it can actually make that boost up high when it cant possibly bleed it off.. If it can do it then u know the issue is boost control (actuator/wastegate arrangement).
Report back and well all help from there.
Yes that's how I've always done it, it did blow my intake pipe off once, took 2 hours to get it all back on and ready to test again. My bov does have a tiny little leak on the outlet side between the bov and the pipe adapter, not a problem during running. I no longer have the pipe that goes to the intake pipe from the tappet cover, that's the pipe I put my finger in. You can see it in the photos.
it will make over 20psi at 6500rpm, hard to hold it steady there without going stupidly fast. so i crept up to 6500rpm at between 15 and 20 psi then i put my foot down a bit quicker to see if it would make 25. not sure if this is a deffinative answer but makes me feel better. so new actuator and new tune and my car should be fine, hopefully the heat soak issue will be resolved with the tune. thanks everyone.
whats running to your p/s pump if your using that as a boost source?
is the p/s side blocked off?
did you use new hose for your boost to wastegate feed? one of the factory lines has restrictors in it
DVS can you pm me a prIce on a retune please.
Thought i did buddy, ill send u another one.
Let me know how u go with the new actuator, more preload, and put the boost source for the actuator in the cooler pipe just out of the turbo.
How long ago in that HG thread did I say it was the actuator lol.
This IS a definitive answer. Your car made more boost at points it never could when you eliminated the actuator from the equation. Done and done. Get that new bitch on her and enjoy.
Sarge. I did believe you but I didn't have a safe way to test it, that's where my wife comes in handy.
There isn't any boost feed going to the ps pump, I used new vacuum line to the turbo.
Yer I deleted it by accident and couldn't remember what you said.
That's the vacuum valve on a neo rb25. That's what I took the line off, il trace the other line and see if it's causing a leak.
Edited by lilcrash
I thought the Hypergear turbos had a nipple on the outlet of the turbo already for that purpose...
If not, do as Jez has said and put a brand new nipple on the intercooler pipe, nice and close to the turbo.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
