  • Replies 886
There isn't anything hard about bolting a head on.
famous last words....
or is this the famous last statement "What do you think I'm going to do wrong?"
you basically have ignored every answer you've received, is this a build thread or a question thread???
Just to clear things up. My machinist is doing as follows. Bore/hone/shave the block, install crank collar, remove aluminum plugs and install grub screws in crank, polish/balance crank, install new crank bearings, put pistons on the rods, install pistons/crank into block.
I will get the block back and install the oil pump and water pump, bolt the head and sump on, install the timing belt, install timing cover/can covers. Bolt engine to gearbox and put the whole thing in the car.
Have I missed anything that the machinist should be doing?
Not all of it, I haven't paid for the bearings, grub screwing, crank bush or balancing yet.
It's going straight from my garage to the dyno to make sure my tune is safe enough for the run in. I can't think of anything that could go wrong but who knows anything is possible.
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
