Lol. Someone came back :D.
How far is your workshop from rydges at north Sydney? We have a credit for $300 to stay there from last year when we were supposed to come down but my wife got pregnant and we didn't feel comfortable flying. I'm considering driving down so you can do my tuning.
  • Replies 886
Oh dear. If you can't tell the difference between foot pounds and nm you're screwed. Id get someone else to assemble...
Also, there is a special tool that you use to file rings.
How the hell did you do it?
I thought you were actually starting to do well... until.
I wouldnt be sure of myself with a fresh built engine, Id get someone experienced to this stuff just so I know its done right, the money spent on engaging someones experience now will be money and worry saved in the long run...
How were you going to drive down to sydney area to get the car tuned, would that mean you would be driving it all that way untuned?
doesnt sound like a good idea to me...
I read the wrong side of the torque wrench. It was only the oil filter mount and thermostat housing anyway.
I'm getting it put on a dyno before I drive it to make sure the tune is safe for running it in. And I was going to hold the wastegate open for run in anyway.
Wat?
You need pressure in the cylinder to bed the rings.
I was thinking the same thing Wolverine, I admit I have made mistakes in the past but the less people that know them the better. lol.
When asking for help its good for you all to know what has happened up until now. I've got nothing to hide. I admit I made some mistakes but it's all a learning curve.
The only concern I have is that I may have a few dog hairs in my engine, I think everything else has worked out ok.
Trust me I will be doing minimal driving until its tuned properly. With a baby on the way I can't afford to do this again.
How long does it take to run in an engine on a dyno vs in the road. Liked if I get my tune checked, I might just go for a late night mountain drive. I'm thinking mt nebo and mt mee and mt cootha all in one night. That should get me my 200km before the first oil change.
Yeah I'm using the hypergear atr43 ss-1. Going to run 14psi or as low as possible if I can't get the low.
Ok kewl, il plug it and if there is an error il know why, this big earth terminal plate is driving me nuts too.
Edited by lilcrash
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
