hi all
learning a lot about my car over the past few weeks :)
anyway, how hard is it to change the rocker cover gasket on an RB25DET Neo engine?
do i need one each of:
http://justjap.com/store/product.php?productid=18578&cat=318&page=1
http://justjap.com/store/product.php?productid=18577&cat=318&page=1
do i need any grease/gasket goo as well?
easy enough to do while i'm changing spark plugs?
also, CV boot replacement quote of $200 (front driver side only). is that reasonable? or should i get a quote from a specialist CV place?
many thanks all :)
https://www.sau.com.au/forums/topic/381676-rocker-cover-gasket-cv-boot/
Yeah you need both and you need the half moons that go with them......
as for the cv boot get another quote i wouldnt pay more than 150odd
these things?
http://justjap.com/store/product.php?productid=18579&cat=&page=1
how hard are the gaskets to change?
this link looks good?
http://www.skylineowners.com/forum/showthread.php?p=1509814
looks like i need some gasket silicone too?
would Nissan sell the gaskets cheaper?
Edited by Stooge007
^^I'll see your $120 for a cam cover gaskets and raise you a full OEM engine gasket kit delivered for $200.
They were wanted in a hurry.lol When you live out of the city it is difficult sometimes getting parts.
When I pull down the G to turbo it I will take you up on that offer.
this is what i need, yeah?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200668207240&fromMakeTrack=true
have asked whether it will fit the Neo engine, and about the half moon seals
I would also consider paying the extra for a full gasket kit and sticking whatever you don't need on the shelf. Usually within 2 years you will need one or more of the other gaskets.
If you haven't done a 100,000km service, consider ordering the "60,000 mile" service kit while you are at it and get him to combine postage.
thats the guy i got my timing belt kit from
$260AUD to my door!!!!!!!! and it was all genuine nissan stuff too (the kit had waterpump and the pulleys too)
and it was here pretty quick too
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
