  • 3 weeks later...
Hey guys, what's the most affordable option to get onto EC for a track day? I had a look on the ARDC site and all I could find were Track days (which start at 12.30pm so it's not even a full day) and they cost $340! Last time I looked the L2S days were about $190, but I can't seem to find them. I'm considering supersprints, but my car isn't rego'd or have a cams logbook. Any other ideas?
Cheers!
Cheers!
I went to http://www.skylinesaustralia.com/forums/topic/400359-eastern-creek-north-track-day-sat-02-june-invite-to-sau/ and had a great time - recommend any day Brett (WalkyHR31) puts on. It was raining and 5 cars ended up bent... I cut up the others in my session - Fed RSRs are great in the wet :yes:
Turns out that Eastern Creek still runs the L2S days! Here's the calendar:
7 September - Cars / Bikes / L2S (South Circuit)
21 September – NSWMRC COMPETITORS ONLY (North Circuit)
12 October - Cars / Bikes / L2S (South Circuit)
20 October – Cars - COMPETITORS ONLY (Full Circuit)
7 December - Cars / Bikes / L2S (Full Circuit)
And pricing:
A.R.D.C. Members – $105 (including GST)
Non-members – $135 (including GST)
Garage (optional) – $25 (including GST)
Which is damn cheap. They also accept AASA licences which I wasn't aware of. Hooray :banana:
EDIT: Does anyone know what they mean by 'COMPETITORS ONLY"?
link: http://www.ardc.com.au/articles/General/Sydney-Motorsport-Park-Private-Practice-Days-2012/68
  • 3 weeks later...
Watchin that video, the category they r in doesnt seem very even. Those 2 commos fired past half a dozen cars before turn 1, then continued to pull away. I can believe the guy is allowed to race, hes rubbish.
its the production car category that I race in, there are 5 classes, he is in class A but didn't do qaulifying so had to start at rear of grid (40 cars back). Plenty of cars finished in front of him, mostly 4wd turbos eg emo Xs.
the driving standards of course have been a point of frequent discussions....who needs repair bills.
Repair bills indeed!
Interesting class. with such a slow field, you'd need to carve it up as fast as possible. Cant clearly see the first shunt but the second certainly should have him before the stewards.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
