Well I'm a bit outta the loop with everything of late... So a few of you can help me this time for a change :D
Parts so far:
CPU: i7 2600k - $330
RAM: Corsair CMP8GX3M4A1600C8 8GB (4x2GB) DDR3, 1600MHz 8-8-8-24 - $170
Also includes RAM cooler in package (usually around $30)
GPU: HD6970 of some description - $400
CPU Cooler Something around the $100 mark should do.
CASE/PSU: Have a Corsair HW650 & a big case, so all covered there.
Parts I'm struggling with:
MOBO: Had good experiences with Gigabyte boards, so thinking a Gigabyte GA-Z68X-UD3R-B3 Motherboard, $185
I just need the board to clock well, aiming for 5.0ghz on air from the 2600k :thumbsup:
SSD: No clue here at all. I would imagine something around the 120-200gb marker. Just have no idea with the whole TRIM stuff, series 1/2/3 SSDs etc. Really not been following it.
Total so far: $1185 (excluding SSD)
Have at it boys :D
https://www.sau.com.au/forums/topic/382571-new-pc-build/
  • Replies 47
You can't pick your RAM before the board. I have had Corsair RAM simply not work in a board...looked at the QVL, not listed, somad. Sent for RMA...completes every test, which it did in the board too it would just crash windows as well. Tried setting timing manually, upping voltages etc etc, nothing could get it to work. RAM from QVL list works no issue.
SSDs there are a lot more to choose from now. I'd stick with the newest gen possible, preferably intel (generally expensive).
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6102582
Parts so far:
CPU: i7 2600k - $330 -Go for the 2700K which is coming out.. pretty much right now
RAM: Corsair CMP8GX3M4A1600C8 8GB (4x2GB) DDR3, 1600MHz 8-8-8-24 - $170 Seems massively expensive.. why not go for a 2x4GB kit? Should be about ~$70
Also includes RAM cooler in package (usually around $30) Wouldn't bother, RAM makes SFA difference
GPU: HD6970 of some description - $400 Good
CPU Cooler Something around the $100 mark should do. Hard to go wrong here, but Noctua or Coolermaster seem to be pretty good. CM212+ is only ~$30 for example
CASE/PSU: Have a Corsair HW650 & a big case, so all covered there. You will need a bigger PSU if you want to overclock IMO, more like 850w
I just need the board to clock well, aiming for 5.0ghz on air from the 2600k :thumbsup:I have this board, works great but I can't get 5.0. I got 4.8 with lots of volts but I wasn't comfortable with it, so now I just run 4.5. In the scheme of things it's only 10% difference...
SSD: No clue here at all. I would imagine something around the 120-200gb marker. Just have no idea with the whole TRIM stuff, series 1/2/3 SSDs etc. Really not been following it. This is one of the fastest developing areas of the PC world, it changes so often that I have NFI. I have 2x 128GB G.Skill drives. They work, er, great! Hah.
Have at it boys :D
Sounds like a one-off problem more than anything else, I don't really think it's true as a rule. Although some RAM is specificially designed for 2nd generation Core CPU's that have XMP (Xtreme Memory Profile)
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6102627
Well of course ill check compatibility once a decision is reached, I'm not that silly :)
A set of G.Skill ripjaw will be the 2 choice, around the same timing.
And to answer why 4x2 over 2x4 - I want to push and overclock hard. You need good ram to do this and I want 8gb. No more/less and this config whilst bout $50 more (taking cooler into account) is good spending IMO.
I will do more reading on XS for branding and chip batches closer to decision.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6102664
Ye I know, however ram speed will still need to be dropped in most cases, resulting in even tighter timings... Making for snappier system etc.
I noticed good gains with my old gear and playing around with ram etc. Not huge, but spending the extra $50 really doesn't both me as i will do a few days of solid benching with it etc as i do with all my new setups to test the limits :D
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6102732
People on WP seem to be recommanding the Asrock Z68 boards as the best bang for buck atm with proven OC ability that matches those from the more 'expensive' brands...
IMO the best one atm is the Curical M4. Best blend of peformance, speed & reliablity short of going the expensive Intel SSDs. None of this "my computer is freezing/BSOD after installing an SSD" that I hear a lot from the current gen OCZ Vertex 3s. The lastest 00009 firmwire for the Curical brings some extra speed boost.
I got one from PCCaseGear (128GB version) & have being using it for several month now & no problem what so ever.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6106044
Hmm, I haven't had any problems with the OCZ Vertex series; I'm running about 12 of them in different machines at work (most as boot, some as database drives).
Biggest thing I found: Don't sysprep your installation across; just do a fresh install and it's frigging brilliant. But hey, I'm sure there's better out there. There always is.
(just my $0.02)
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6106882
Are they the current Vertex 3s?
Those are the ones that have the reported problems due to the newer sandforce controller in them.
Have 2 friends with them & both are having freezing BSOD problems & the there seem to be a lot more cases being reported on WP forums.
But the Vertex 2 my parents had, have no problems for over a year now Statistically speaking I think intel SSDs have the lowest failure rate, but they are also the most expensive ones around.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6107098
Parts so far:
Have at it boys :D
I'd personally go for 2x GTX560 in SLI. $200each...
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6111211
Nah that's one thing I don't wanna get into - SLI or Crossfire.
Friends of mine have too many issues with both to justify it for me. Mate is getting rid of 2x GTX280 for the GTX580 for just this reason.
I mean i could get 2x 6950 for around $500 and really stomp things but i cannot handle the headaches.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6111261
For a CPU cooler, get the Coolermaster V8, I paid $60 for it. its quite big, but keeps my i7 2600k very cool, 20 deg or lower on idle and maybe 35 - 40 on load/gaming.
And as for a GPU, I wouldnt bother buying a 6970 because the difference between a 6950 and 6970 is minimal, not worth the extra $120~
I bought a HIS 6950 IceQ 2GB for $276 with a free game (Dirt 3).
For a Motherboard, i bought a GA-Z68XP-UD3.... plenty of features, very stable... well worth the money. $152. Highly recommended.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6111308
there were alot of problems with the 200 series cards. i managed to kill 2 of the GTX 285's by myself.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6111463
Mate of mine just went with the G.Skill Ripjaw kits, and I'm looking at going the G.Skill Ripjaw 1833MHz kit. For the price you've quoted you could get 16GB RAM.
Corsair 8GB: 1600MHz 8-8-8-24 ($140 effective when you remove cooler cost)
G.Skill 8GB: 1866MHz 9-10-9-28 ($90)
Fair performance different between the two, and from what I've found digging around the Corsair will hit 1900Mhz @ the same timings which is quite impressive. I do a lot of Unzip/Zip which will see a good 15+ sec difference each time on large files (10gig+). Saving a good 15mins over a week is win for me :)
Still digging around though with memory. Perhaps there is a cheaper option around the $110-$120 mark with awesome chips on it that a company has tried to fly under the radar (which often happens).
Will peruse the XS forums more for that, those guys always know what's going on in that regard.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6111716
get Sandy Bridge Extreme fark ya, 64GB of RAM ftw!
also, SLI haters should get over it, my 460's are awesome, and I've managed to convert all of the SLI haters in the office after a year and a half of no issues, and more performance with my 400 dollar setup then their (at the time) 700 dollar 580's! Crossfire is apparently still fairly shithouse though.
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6114349
LOL SB-E offers nothing, step back even.
Still not going dual card. Just not interested, not haters really, just know more people with problems than without which is not what I build a PC for. I like my machines to work flawlessly... I have enough trouble at work :D
https://www.sau.com.au/forums/topic/382571-new-pc-build/#findComment-6114383
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
