  • Replies 130
Good job on the research, saves tears later.
As before; I'm in for 2 sets, PM me some details & I'll cash you up.thumbsup.gif
Cheers. I just hope my research is correct :)
Shouldn't be a prob, if anything like the guy from SPC Performance said, the bolt might just be a few mm long but it's not a problem. Better a little long than short.
I'll PM everyone payment details Wednesday night.
Edited by slippylotion
Ok guys, the chance to get in on this buy is now closed.
I will PM everyone listed below the bank details and final price excluding postage within Australia from me to you.
Please don't pull out of this now as the final price everyone gets is worked out on everyone listed below still paying.
The guys in the buy are:
Slippylotion (myself) x 2 sets
Daleo x 2 sets
Scotty nm35 x 2 sets
Commsman x 2 sets
prince_skyline x 2 sets
skip_o_valov x 2 sets
Thanks everyone for getting in on this so we all save a bit of coin on these.
The shipping from the US is standard international so please allow a few weeks for arrival. As soon as they arrive I will contact you all to arrange postage to you.
Cheers
  • 3 weeks later...
The bolt kits are here guys! Just in time for christmas holidays to fit them on that lazy day.
PM will be sent regarding postage to each of you.
Thanks a heap guys for joining in with me.
Cheers
No problem, so what do we use to slot the hole? Is there any instructions?
The square white piece of card is a template for marking out the wider slot; you just colour with a marker pen and use a die grinder with a rotary burr or dremel to widen the slot.thumbsup.gif
Yeah they come with instructions. Can use either a dremel or die grinder. Maybe a bastard file if you have plenty of strength and time ?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
