  • Replies 105
Posted Images
That was a great idea Steve, I'll try to drag don along next time. Had a lot of fun and to finish close to Eric's GTR is a good result for the humble FC. Thanks Eric for the run, and rerun when i changed back to normal wheels. Battling is way better on rubber with tread :teehee:
Yeah Chris, I originally wasn't going to run my car at all. But, the slightest twist of the arm and well GD2ILA was itching to have a small strech of the legs.
Was good fun! I have some video that Matt was kind enough to film too so will put that up soon.
A little more awake now.
Thanks to officials for their time and efforts. Thanks to Reece for jumping in the car to give to me pointers, I may have seemed very confused but your tips through the day made a big difference. Slower is faster but it's hard to resist the temptation to make the tyres scream. cheers.gif
Did anyone get a shots or a video of my Stag going around? Would love to see it doing it's thing, hopeful of the one hand break turn that was right.( out of many attempts ) thanks.gif
For a first timer everybody made me very welcome. Anybody sitting on the sideline worrying about being a novice or breaking your car - don't be, it's all at your own pace. As for breaking your car - refer back to previous comment re slower/faster. thumbsup.gif
I now just need to sort a new clutch before the next one so I can do those 6k launches . nyaanyaa.gif
and yes this thread needs more photos and videos.
You did great! And I think another point to make is that you drove home on the tyres you came with... so anyone thinking it's an expensive day out cos you need 11ty sets of tyres (as previous pictures would have you believe :P ), it doesn't have to be!
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
