  • Replies 52
James, count me in buddy!! I'm in desperate need of some sexy tint. You reckon though that these mobs can do at least 20% tint? None of this moral fag crap 35%...
Yeah of course, i spoke to them about that, they said they can do any % you want but obviously if its illegal tint they wont be held responsible.
forgot to call that other dude, will try and remember monday
What's the difference in cost for a 4 door? Should be roughly the same yeah as 4 door 33's don't have that extra little quarter window as lots of sedans do. Obviously it would use slightly more material but it would also be an easier job than a 2 door as it's easier to access the windows?
Just spoke to Brett, he said $150 for skylines or $170 for 4 door skylines, other cars you will have to call him for a price and his still in ferntree gully
Very nice, could be interested too mate
I had 15% on my 31 years ago @ night you literally cannot see anything, even headlights are hard to pickup. Was actually a bit dangerous to be honest.
Especially now with RWC requires them to check the tint... Suggestion would be to go 35% on the doors and then 25% on the side/rear windows :)
35% works well on the seeing windows if you have it darker on the side ones etc.
Less light on the inside and so on making it appear darker. :thumbsup:
I might get mine done next week actually now i think about it
Will be keen to see some pics on how it ends up
