I went to Deca this weekend and noticed a few interesting things about the way people drive around these short technical courses. My car has blistering straight line speed but I found getting around the corners in such a big car was extremely hard. I few points to note are the amount of drifting that was done and the constant handbrake turns that were used around the corners. These two driving styles alone could win or loose the battle against your oponent.
Two things that I didnt do were any handbrake turns as I wasnt sure what the effect would be on the driveline given everything is still mechanically engaged and then suddennly the rear wheels lock up it surely can't be good considering I have no clutch. Can anyone shed any light on the subject?
The other item is that I never drifted, the VDC was in Race Mode (Not off) so there was no real way to keep the wheels spinning. Is it possible to (4 wheel) drift these cars with the VDC off?
Another thing I noticed was how bad the car aquaplanes in the wet with even slightly worn tyres. I remember the original set of bridgestone was almost as good in the wet as the dry, this was the most dissapointing part of the whole day, the lack of traction, I basically had none.
https://www.sau.com.au/forums/topic/383602-handbrake-turn-r35/
Will be tricky to get the rears to lock up as you have said.
best bet would be some really sticky front tyres, so you can use the brakes to get the car to dance around / pivot on its nose.
Will be hard to master but doable
hahaha what do you expect with toyo triple 8s, they are more of a cut street slick than the bridgestones - grooves create wet road grip
afaik even with VDC off it still brakes the wheels to a slight degree
the R35 is in no way setup for DECA style events - it's too wide, too heavy, too powerful even
did anyone take any vids of your runs? post em up boiiii
Edited by domino_z
To handbrake effectively the clutches need to disengage.
With the EMO X SST the clutches actually disengage with handbrake activation. The R35's don't do this I'm told.
It was one of the first questions I asked about the car!
Wrong kind of car for the event I'd say. It would do well on the wangs (small sections of race track at the back of the facility, for those who don't know), but on the skidpan with our layouts you need something light that can pivot on the spot. Handbrakes aren't essential, but you do need to be able to swing the car around very quickly, which I imagine to be quite a hard task with the R35 (heavy, no clutch). People have won these events in Echos/Corollas...and the Evos usually do very well on the skidpan.
Ill go back and do it again with a new set of tyres and hopefully in the dry and see if I can throw the thing around better. As the track dried out later in the afternoon around 3:30pm i could start getting some good power to the ground but they weren't timed runs at that stage.
Yes you can slide the R35 around all day, encourage the rear to slide on corner entry by getting the weight off the rear tyres, try lifting off or braking then turn the car with weight over the front.
Avoid excessive oversteer on corner exit, it is fun but slow. Think "point and shoot" for the R35 on this type of course.
Take a passenger who can read the course map and guide you through too.
And as everyone is saying, it is the wrong car for the job so don't expect to blow everyone away.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
