Ok thanks guys!
And as far as good and bad catch cans, there just cans! as long as they dont leak how is one better then another?
There's a difference between a simple 'catch can' and a proper oil/air separator.
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6119409
Ok thanks guys!
Size need to be at least 2Litres (or to suit regs if you're racing)
and some kind of baffle system to encourage oil and water to precipitate into the can and just let the gas go out (to atmosphere for track car or inlet for street car).
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6120541
There is probably a viable off-the-shelf item, but I want mine to sit in a specific spot so custom is the way to go for me.
That said, I'm yet to actually find a decent looking off the shelf one... Anyone had much luck with that? I know RIPZ makes them, but I believe only on request?
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6121846
im not to sure im trying to work it all out myself now but as i mentioned before would steel wool do the trick
the only way i can think it would work is say you have the inlet and outlet next to each other and have a partition/baffle in between made from fine steel wool so its like divided into 2 tanks inside by the steel wool so air and oil go in one side and just air comes out the other because the steel wool has caught the oil on the way through
Edited by luvpsi
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6122200
If you had a square tank you could easily make baffles out of square pieces of metal which left a gap and alternate the gap left and right so that the stuff that comes in has maximum contact with the plates and the liquids drip down to the bottom of the tank .
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6122243
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
