Cheers bud its getting there
Got a w/a today cheers ryn u are the master!!
Painted up strut brace and fitted!
Finally fitted adthree front bar
Yea so as u can gather I drove the car today! Yeeew!!! Couldn't wait ne more surprisinly car drove really well steering rack feels good! I'm yet to push it so still looking 4ward to c how it performs
did a bit over chrissy to it, started on the inlet manifold FFS wat a shit job! i feel for the guys who do these in 32s and stags! no room, hidden bolts everywhere! but yea after sum swearing and a few cans i got it all off,
ok with inlet finally off i decided if i had to do the job again, id make it easier for my self, so since im not running a iac, its all goin, bloked off one port and all i need is a a reducer to join to the other to go to the booster.
properly mounted coil pack and made up new sparkplug leads
pulled rad out and started on mounting up thermos.
Hey Harry, finally joined and finding my way around the SAU Forums and spotted this. I knew it had to be you with all those engines you have gone thru!
Now I can keep up with you on your car antics without having to call you every now and again. Looks good mate.
Am about to put up all the info on my HR31 in the next day or so so stay tuned.
Brett
Brett
haha hey brett!! yea theres been a few of them now! hopefully this one lasts a lil longer! good to hear from you, likewise im keen to c the new mods on your H R!!
Really diggin this build/car man, top job!
I <3 DR's and yours looks fantastic
the engine bay pic makes me want to redo mine :thumbsup:
cheers mate, yea never thought id go this far with the bay, kinda wish i hadnt painted it, everything now needs to be stainless or new or shiny,its killing me lol
  • 1 month later...
yea so havent really done much for a while, i got it tuned made 270kw on 18psi, not really happy with the number but what can u do it still spins 3rd no problem, already been through two sets of tyres and i havent even been to a skid day haha
both thermos are all fitted up and wired, work sweet
fitted a schroth 4 point harness, ive got a bride bucket seat i use when i do events, stok seats for daily duties(im fat and getting old haha)
lowered the bonnet also, looks heaps better
Edited by ydr030
I was thinking about the z tune vent hoping id start to like it but its shit so binned that idea.
I twisted my painters arm and finally got him to paint a metal bonnet for me turned out pretty well
Big thanks to zack @ forest autobodies
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
