I might be up for some Steering controls only. Not interested in the Cruise control side of things. If I get the tuning of this ECU down, it can store up to 5 ECU Maps. You can trigger them via the factory Cruise control buttons.
I'll let you know once I get it sorted.
Cheers.
Hey Alex, appears there could be a few sets of controls floating around looking for a home. I'll make sure I put you in touch with someone selling when the time comes.
So your ECU can be set to look for different resistances across a pair of wires to determine what map to use...? That sounds very cool. What would be nice is to be able to change the writing so the buttons say stuff like ECO, STD & POWA, for example, lol.
Its activated by holding down one of the buttons and then toggling up or down on the .... well, toggle thingo. Up to 5 maps, so you could have power, econ, and a valet map with speed limiter set to 25km/h / 2000rpm, Or a kill map so the car wont move anywhere.
Got to figure out if this systenm works yet, and tune it, so count me out for a little while on the buttons, but down the track I might get some :cheers:
I have a similar set up for my 180sx. It's a PLMS 4 map switchable on the fly daughter board in the stock ECU.
1- 98oct.
2- 98oct valet (3000rpm limit and 60km)
3- E85.
4- E85 valet. Same limits. Can only make 8psi by 3k but then the speed limit hits.
Works a treat. I switch to the valet map and unplug the small controller if it goes to a tyre centre.
PLMS don't offer this set up any more.
Edited by slippylotion
Sorry Cam...
Couldn't wait... Wife got 3 seperate speeding infringement notices in the post today... All on Eastlink over a 1 week period before Christmas. Over $500 and 5 points as well... Cruise was fitted and installed in the Stagea 2 hours later...:thumbsup:
Just need to teach her now to use the cruse on the XC90 now... She is also now terrified of the postman...
Yes. If you can wait until receive mine, I'll also swap the fascia so you done have to cut (and mine won't have the hole)... if you want... and Jules pulls out.
Hi Lean,
Cruise fitted and works great!! Thanks again for that. Just need a quick re-adjust on the angle of the stalk, but that is only a few screws to get at. Also took the opertunity to fit a long overdue replacement pollen filter, when I had the passenger side apart..
Nick
Hi Nick
just want to say "ouch" pinch.gif . I hope the cc keeps the postman away from now on, lol.
Hi Commsman
Just wondering if you still have any of these kits, and how much it would be delivered to Sydney.
Cheers mate,
bebetaz
G'day.
I'm waiting on some throttle harnesses to arrive that were out of stock when originally ordered/shipped. I'm taking EOI in these & only have 2 places left to fill. Price is $490 delivered to anywhere in Aus.
Cheers, Leon.
  • 10 months later...
Hi Leon,
I know this is kinda late but do you by any chance have a set of those cruise controls inclusive of the steering wheels control left?
Im located in WA if that affects anything.
PM me.
Cheers,
Nicholas
  • 1 month later...
Sorry guys, I don't read here very often.
I had lost a cruise control box in the garage somewhere & only found it during a post Christmas clean up - but it has been promised to another guy.
I guess I could be willing to do another run of 20 units, but it's a lot of $ to have sitting around. Anyone wanting to go halves?
  • 4 weeks later...
Mmm, so that's 5 people interested. I can only buy them in lots of 20 so really need a few more or else I'll be left holding the baby, so to speak.
If the count gets to >10 confirmed people I'll seriously look into it. Also reckon a good idea would be to have a discount for those that pay before I need to transfer the money. That might entice the fence sitters' to convert.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
