  • Replies 5.5k
Posted Images
As for why Webber feels more comfortable in the updated car, Marko added: "Mark is less sensitive to the [car's] behaviour. He just needs four wheels, but it's different for Vettel."
what he really needs is wings
RANK TEAM NAME POINTS 1 1 au.pngWebbull 183 2 1 au.pngSau 166 3 3 au.pngNubs's army 125 4 1 au.pngNJSracing 116 5 2 au.pngJteam 112 6 2 au.pngstR33ter 109 7 1 au.pngKimiUmp 108 8 1 au.pngDori34Racing 102 9 2 au.pngLooptrooop 101 10 1 au.pngFishos 97 11 1 au.pngMissileman 89 12 4 au.pngMacGillaZ 81 13 1 au.pngScottydoo Racing Mega Predictor 74 14 au.pngScuderia Dezz 73 15 au.pngSniper Racing 71 16 3 au.pngN1GTR 63 17 au.pngmad082 27 - au.pngOZHCR32 0 - au.pngSMc_F1 0
i'm last of the point scorers, but the chinese GP was the first one i did
Of course not, he is the driver essentially on the out. Unless after 3 more races and Web's is higher in the points scale and performing better etc - then it'll still favour Vetool.
Don't forget that Web's has only really risen back to the spotlight so to speak because Vetool is not performing, combined with the flat tyre etc. I think it's still way to early in the season for RBR to make Vetool play 2nd fiddle. If only Webber could start a F1 car as good as other drivers, the start hurts his entire race. Imagine he started well like all other drivers from his quali positions, would be a much better first lap out as being mid-pack has so much risk with being taken out!
maybe they are giving mark a few extra chances because it is going to be his last year for 2 reasons. 1: if they can send him out as WDC would be nice. 2: if it makes it look like they don't favour vettool so much then when mark leaves they might get some better drivers willing to come to the team thinking their might not be so much favourtism. but once there they will revert back to last years setup where bieber gets first and second preference.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
