  • Replies 5.5k
Posted Images
Its 2010 again when after Silverstone there was talk that Webber was off to Ferrari. I doubt it but would be a cool way to finish up your F1 career
http://www.planetf1....Perez-stop-gap-
imagine if webber did go to the fez. would lead to possibly the best team mate racing in F1 for a long time. i don't think the team bosses would like a repeat of Eau Rouge from last season though
anyway, back in 2012
Mclaren have tried to secretly test a new nose in Mugello
Oddly, they only used it for in and out laps, in the hope nobdy would notice. Theres absolutely no mention of it on technical forums or websites, which is strange as its a decent change in philosophy for front end aero.
Left is old, right is new
Oh the noise up that famous hill.....
And the old layout seems more of an adventure. Gutted it changed before I got there
Webber has always gone well up against Vettel in Spain. Here is to hoping he can edge Vettel and others out and start a nice little patch of victories and podiums. I am tipping RBR this weekend to be strong along with Lotus...McLaren will struggle again is my tip
the new nose gives me the impression that it may have a bit of flex to it. probably won't, but for some reason that curved look just makes me think of flex
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
