  • Replies 5.5k
Posted Images
Who would have though a Venezuelen pay driver would have brought Williams in from the wilderness. Senna is going to have to lift his game. As are Red Bull.
Just hope that fire is not going to cost Frank too much money. Anyway, looks like winning stuff is good for the share price:
http://quotes.wsj.co...teractive-chart
Edited by djr81
5 place grid penalty for the Schu next round to confirm whose fault we all knew it was regarding the Senna incident
I don't know about the Schumacher penalty... Watching it at the time, I thought it was all Michael's fault, but this slo-mo shows Senna drifting right initially (there's a clear refence with the pit exit line). That led Schumacher to commit to the outside, then Senna jinks back to the left to cover that move. That's a second move to defend position in my books. But even if you don't agree on that, tell me the subsequent move to the right by Schumacher wasn't caused by Senna's sudden jink. Its all pretty clumsy, but I think a 5 spot penalty for Schumacher causing that crash is a bit harsh, when it was just a reaction to Senna moving back to the left on him and probably worried he was going to run him off the road. If Senna had kept going left, they probably still would have crashed because it was all too late...I just don't think you can put all the blame on Michael there - he wouldn't have made that move back to the right if it wasn't for Senna's sudden jink back towards him.
http://www.youtube.com/watch?v=kfls8VLYZr0&feature=related
Senna only moved once to cover the move the again back to the racing line which apparently they outlawed that at the beginning of the year but every has been doing it all year so you can't blame him for the crash if they have any consistency.
Clumsy on Senna's part, but at MSC should have left himself more room so he takes at least 75% of the blame in my eyes.
MSC was whining about Senna braking and moving back to the racing line like it was a sin but there is no rule against that is there?
Edited by NISMATT
the sudden-ness of that Senna jink was not a "I'm just returning to the racing line now, ok?" That was a "get stuffed, you're not going that way" sort of move. He didn't go through with it, but turned out Schumacher bought the "dummy"
Yeh Schuey had a "I am confused moment" and ran into the back of Senna...easy to see how it happened with Senna moving around like he was...racing incident to me and doesn't deserve a penalty
Re the pay driver tag that Pastor has had to wear...as a rookied he did a knock up job alongside Rubens, he was impressive in Australia despite dropping it on the last lap...and he drove a damn solid race, strategy was good, out lap pace was waaaay better then Alonso and was still able to get the required life out of his tyres. So stoked that he got the job done....hopefully the tag of pay driver will be forgotten as he obviously has the ability....$10 the likes of Fisi and many others would have made mistakes .... seems like 2011's pay drivers Perez and Pastor actually have the goods
well that all depends on whether he can finish on the podium again this season...
Weber ploughed right up Kovalainen's arse in Valencia 2010 under similar circumstances with DRS open and a high closing speed, and a car in front braking early due to worn tyres. But no dummy jinks from the car in front, and Weber didn't even pull out to try and pass one way or the other. Just ran clean up his arse without even braking. Did he get a 5 grid spot penalty??? no... nothing at all...
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
