  • Replies 5.5k
Posted Images
How fitting is it that Kimi has a James Hunt tribute helmet this week. Far cooler then the diamond necklace helmet Seb VeTool is sporting
Worrying is that RBR are nowhere with regards to pace. Lotus look good so hope Webz, Romain or Kimi can get the job done and Disco Dan get a strong finish...the trend is worrying that Vergne out races him every weekend :(
Bit awkward, Formula One.com thought it was Friday practice Two. Guess you write it 19/20 times a year and it becomes habbit
http://www.formula1....12/5/13380.html
The rain came to Monaco sooner than expected on Friday afternoon, which rather spoiled second practice as the times became academic thereafter
Weren't Mclaren sponsered by some Jewelery company, where Kimi once had a diamond studded helmet for the Monaco GP (the first time he had the Matte black design) I guess that sponsership no longer exists?
Edited by 89CAL
possible 100 million pound McLaren deal for Hamilton
http://m.guardian.co.uk/sport/2012/may/24/lewis-hamilton-mclaren-new-contract?cat=sport&type=article
why couldn't my 'rents have got me into karting when I was younger :(
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
