  • Replies 5.5k
Posted Images
Kubica undergoes surgery to damaged elbow
Robert Kubica has undergone surgery in order to improve the mobility of his arm following his accident last year.
The Pole, who continues recovering from the horrific crash he was involved in during a rally at the start of last year, had surgery at the Pederzoli hospital at the end of last month, when parts of his elbow were replaced with two prosthesis.
According to the doctor in charge of the operation, that will allow Kubica to fully handle the steering wheel of a car.
The doctor also said that the Polish driver had been carrying out tests in a simulator prior to the operation.
"This way the driver will be able to fully handle the steering wheel, while before he was unable to rotate the palm down, so he was forced to release the steering wheel in order to turn left," head surgeon Ruggero Testoni was quoted as saying by Italian media.
"The surgery was preceded by a series of tests in a car simulator. It will take at least one month in order to stabilize."
http://www.autosport.com/news/report.php/id/100151
Haha where do you find these Formula 1 memes?
And what happened to all the Hamilton ones when he had his gay photos for his singing career or whatever the hell that was? Was expecting many laughs
dick around on the net long enough and you can find anything
What's everyone's thoughts on Aussie Dan, if he continues to perform the way he is he possibly won't have a seat next year
oh wellz
bring on the next one
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
