  • Replies 5.5k
Posted Images
How do I improve the quality of VIP Box when live streaming? I have Bigpond and a video card (Nvidia Gforce 8400 - nothing spesh i assmume) and 2 GB of ram..on the home PC
Pedal faster !
not F1 but yay for channel ten streaming the whole le mans this weekend: 25 ex F1 drivers this year too;
http://tensport.com....e-streaming.htm
Thanks for the heads up. :thumbsup:
What I've learnt today- The rassscasse turn at Monaco takes it's name from the 'La Rasscasse' restaurant that overlooks the corner. There you go.
Cafe by day and banging nightclub after dark according to the one and only Eddie Jordan.
F1: Report reveals McLaren tyre temperature trick
Jun.14 (GMM) McLaren is the inventor of a clever system that is helping Lewis Hamilton at the front of the F1 field at present.
Germany's Auto Motor und Sport, with the collaboration of renowned F1 technical illustrator Giorgio Piola, said the British team is using a system that controls the flow of heat from the brakes into the difficult-to-manage Pirelli tyres.
So in a season in which a degree or two in temperature can bring a tyre in or out of Pirelli's tiny 'window' of performance, the McLaren trick is "ingenious", German journalist Tobias Gruner explained.
The team's mechanics adjust the rear braking system in the pits with a screwdriver, the screw being located near the driver cockpit opening.
As Piola's drawings show, the infinite adjustment affects the rear braking system and the flow of braking heat to the tyres.
But it has not been all good news for McLaren, whose Jenson Button is suffering arguably the grimmest period in his entire F1 career at present.
It might have something to do with the FIA's recent clampdown on the MP4-27's floor.
Reportedly after the Chinese grand prix, the governing body ruled that the British team had stepped over the line with its interpretation of the rules regarding flexibility.
Scratches had been found underneath the extremes of the front wings, to which McLaren argued that the floor bending was within the allowed tolerances.
"The tolerance is there to account for manufacturing defects," Charlie Whiting is quoted as saying, after ruling that McLaren's system deliberately exploited those tolerances.
Auto Motor und Sport said: "The seemingly minor change had major implications for McLaren."
Particularly Button. The team's subsequent technical changes, including the higher nose and the modified rear suspension geometry, seemingly worked for Hamilton, but not for the struggling 2009 world champion.
Getting the 2012 car to work for Button again is now a high priority for McLaren.
"The problem is very complex," technical director Paddy Lowe said. "Our car is good, it just has to be set up perfectly."
And at the heart of all the F1 teams' quests for performance at the moment is the mysterious Pirelli tyres.
"I'd say we understand 30 per cent," admitted Lowe.
Edited by ctjet
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
