Pastor Maldonado says he is not planning to change his approach to racing despite the penalties he has been handed this year.
"I think I have been quite unlucky the last couple of races," said the Venezuelan. "Especially in Monaco and Montreal because I got penalised because of the gearbox and I crashed in qualifying in Montreal, but the pace was always there and I think in the last race it is difficult to value because Lewis was losing by three seconds per lap.
"I saw the chance to get on the podium when I had a very difficult race, especially at the beginning when I was P10 and then I had a good race and I was looking forward to getting on the podium as well. One and a half laps from the end I saw the chance to take the position against Lewis and he tried to defend and I tried to attack and it was normal racing contact I think.
"I was disappointed because they were good points for the team and for me but there are many races ahead and the season is still long."
The Williams driver said however that he did not feel the stewards were picking on him for his aggressive driving.
"I don't think so. I have been unlucky but it is like football, and for sure we need to respect the rules. If you do not respect the rules you get a penalty and that is it."
http://www.autosport.com/news/report.php/id/100917
''he tried to defend and I tried to attack and it was normal racing contact I think''.
^ :laugh:
Maria de Villota remains in critical but stable condition two days after her dramatic accident
http://www.autosport.com/news/report.php/id/100929
Silverstone weather forecast for Friday and Saturday is for heavy rain to fall over the two days.
:banana:
http://www.planetf1.com/driver/18227/7870439/Silverstone-gearing-up-for-wet-weekend
  • Replies 5.5k
Posted Images
I miss the old West Mclaren Mercedes paint job, was so much nicer then the new chrome paintjob
has anyone ever bought Formula 1 Prints for there house? Just wondering if theres a good site to get some off
They used to be common as muck a few years back. I think Mobil put them out. Anyway just type Mclaren f1 poster & maybe the MP number (MP4/13?) into a search engine and you should get a bunch of options.
But if it was for home I would try & get soemthing a bit less common. Try here:
http://www.sutton-images.com/searchresult.asp?search=mp4%2F13
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
