  • Replies 5.5k
Posted Images
What the hell were RBR thinking? :verymad::domokun: :domokun: :domokun:
Webz had Nando covered....the dires were very conservative this weekend and were never going to fall off the cliff :(
On a side note ... Sally from Home and Away has aged damn well. She used to live in the same complex as a mate when we were young...wish they were still neighbours :)
Have you seen her in action?
The reason given for the late tyre change was that the diff fault was causing excessive rear tyre wear. But it sounds a bit like a premature call given how well the tyres were holding up generally. Anyway, blaming Mark is a bit unreasonable, his start was brilliant and he went well otherwise.
is this the start of pegging back mark and letting vetool ahead of the points between them? call me sceptical but the would never let mark finish ahead in the points by the end of the year
Sorry to ruin yet another RBR Webber conspiracy theory with facts, but Webber's last 3 laps before that pit stop were getting consistently slower and the last was 2.2 slower than 3 laps earlier. I don't think they had any choice. They also 3 stopped Vettel 3 laps later and his lap times hadn't even started declining.
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
