It seems that Grosjean is having a week off for being noobish and not understanding if he was clear of LH but if the same move was made by an established F1 driver like Schuey, would they have applied the same penalty? They may have decided to clamp down on the next major incident and Grosjean was the first in line.
Grosjean has had several fist lap incidents this year which I'm sure is a factor in their decision as well. And if you actually have that little spatial awareness to know Lewis was there but think he's not alongside you when he has benn for several seconds, then you probably shouldn't be in F1. Here's Kobayashi's spatial awareness for comparison!
http://imgur.com/a/ETPea
  • Replies 5.5k
Posted Images
I think that photoset makes Kobayashi look a bit better then he actually was. He was lucky to get out of that without damaging the car to bad. I don't think it would have been possible for anyone to react and avoid terminal damage quick enough. Yes he did the good by seeing it coming, but I dont think that its down to him being more skillful then anyone else
Come on...you always judge driving in a vacuum. At the same track last year Hamo moved over on Kobayashi and caused a nasty accident at Les Combes. Button moved over on Hamilton and put him into the wall. When its all going on and you are moving past a car and judging whether you have cleared them many have made mistakes in their careers. Others have done and do it. Agree about spatial awareness but Hamo got a poor start and Romain was clearing him and made an error with Hamo still hanging around on the inside.
You have to look at things on merit and you cant say Romain is to blame for the 7 incidents he has had early this year! Australia was a hatchet job by Maldanado. The Schuey clash was a light touch in the wet and a racing incident (More experience may have avoided it) . The start at Monaco was just the meat in the grinder between Massa and Schuey. Romain has had a 2nd, two 3rds, a 4th and two 6ths...he has had one poor incident at Spa. He was probably on for a solid second at Valencia as well.
I like and rate the guy but we have seen this sort of thing time and time again. People forget the changes KERS and DRS have made to race starts. Pre the devices people used to commonly push for gaps that may close up knowing that the first lap was where the race was made. These days everyone is more patient knowing there will be opportunities due to tyre deg, KERS and DRS....so no saying it was not a mistake but I dont get the penalty and all the blood in the water. Either way it will be a good test for him to come back and see how he drives. I still really hope he and Kimi each bag a win before the end of the year.
Just found this to jog peoples memories when they start going about his "overly aggressive starts"
http://www.youtube.com/watch?v=x90zXuS1xKc
I reckon this article has it about right
http://willthef1journo.wordpress.com/2012/09/03/spa-stewards-standards-and-safety/
Yep all a factor for sure.
of course he was lucky to get out of it without car damage. The point was about his spatial awarness and his reactions to it what's happening in split seconds, not to mention the composure to get immediately back on the wheel as soon as they've cleared his car, in contrast to a bloke who'd have you believe he didn't realise the car he was passing was even there...
It seems Webber had a different final gear as well so he was even slower than Vettel. Nothing is payingg off for Webz...hope he gets a fair crack next race otherwise he will lose touch with vettel/Alonso for the WDC
Hate to jump on the "Redbull hates Webber" but the guy seems to be worse off then Biebtool.
Also seems to lack the aggression to make a pass and "get on with it".
example, the passes that Tool made in the chicane leading to the start/finish. Can't see a reason why Webz couldn't have made those same moves...
I can, Skill.
And that's coming from a fairly one-eyed Webber supporter. I think he needs more things to go his way to really get a top result than other drivers who in my mind are better steerer's/more aggressive at the right times who can make more happen from less.
Maybe I'm being overly critical - make no mistake, it's clearly hard work to go fast in an F1 car, I think we've all seen Hammo try it on Top Gear. Maybe I'm just sour that he's not romping away from everyone with win after win, but I just wish he was more consistent and would step up more often.
Edited by ActionDan
A lack of terminal speed due to a shorter gear 7th gear might have left him a few metres behind the car in front at the braking zone.
I can, Skill.
From what I understand Webber was 8km/h down on Vettel through the traps. So Webber was 20km's down on the likes of Hulk whilst Vettel was 12km/h down. May be part of the reason why Webber was just that a fraction further back where he couldn't muscle his way through cleaner.
Webber has had been on pretty aggressive strategies the past two races to try and get positions on the track with pace and passing. Vettel has gone the longer strategies where it was about consistency and cars pitting more than him. It seems either Webber cant get the same life out of tyres or when they are splitting strategies Webber prefers the more aggressive strategies. Based on the past two results I think he needs to consider seriously his ability to pull of China/Valencia results consistently enough to bag points towards the WDC
That's another thing I've noticed about his driving too, his seems to burn up the rubber quicker than Vettel and indeed other drivers also. Whether that's actually him and "he" is burning up the tyres through his style (maybe body weight also? though he has been looking pretty gaunt recently) or whether it's inherent in the cars setup remains to be seen.
The fact remains though, that the current car/driver combo seems less friendly to tyres than others in the field.
And agreed that in this particular race his final gear setup was not ideal, but my comments about his progress are more of an overview and spans 2011 as well, when in my opinion he really should have come away with a WDC. Take all that with a grain of salt though, I don't pour over the stats to back up my claims like some of the guys in here, and I'm glad you guys do because it brings clarity to rubbish claims sometimes, my comments are purely about "the vibe" of it. As a viewer, watching him race, those are the impressions I get.
Edited by ActionDan
the driver and his engineer choose their setups. So if Webber chose a shorter top gear or a bit more downforce or whatever it was (could have been that Vettel just got a better tow the time he set that higher trap speed?), it's not RBR screwing him over.
Formula 1's frontrunning teams could face a dramatic increase in entry fees for next year's championship if plans being considered by the FIA come off.
Taking last year's constructors' championship standings, the entry fees in Euro under that new plan would be:
Red Bull (650 points) 5.050 million
McLaren (497 points) 3.979 million
Ferrari (375 points) 3.125 million
Mercedes (165 points) 1.655 million
Lotus (73 points) 1.011 million
Force India (69 points) 0.983 million
Sauber (44 points) 0.808 million
Toro Rosso (41 points) 0.787 million
Williams (5 points) 0.535 million
Caterham (0 points) 0.500 million
HRT (0 points) 0.500 million
Marussia (0 points) 0.500 million
http://www.autosport...t.php/id/102225
Lotus has confirmed that its reserve driver Jerome d'Ambrosio will take Romain Grosjean's seat for this weekend's Italian Grand Prix.
http://www.autosport...t.php/id/102235
i can't wait for that^.
I think its lessabout tyre wear and more about track position and the undercut. Hence the pitting early and more often
I dunno Bris, in my head there's been a few times when they've pitted because his lap times were dropping off, not because they were trying to be overly tactical, but again, I'm just an armchair commentator.
Some hefty entry fees there just for the privilege of being involved...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
