  • Replies 5.5k
Posted Images
Jean-Eric Vergne has been slapped with a three-place grid penalty for impeding Bruno Senna during qualifying at Suzuka.
http://www.planetf1....ed-for-blocking
Kimi Raikkonen was at his best during a post-qualifying interview at the Suzuka circuit where he made his thoughts on the subject at hand quite clear.
The Lotus driver, who had made it through to Q3 in qualifying for the Japanese GP, came up short in the final minute when he lost control of his E20 at Spoon Curve and beached his car in the gravel.
As the chequered flag was waved the yellows were still out for Raikkonen's car meaning his rivals were forced to back off in that sector.
Asked what happened, Raikkonen said: "I spun."
Clearly...
Asked about the impact his yellows would have on the rest of the field, he said: "I don't care what happened to the others."
You have to love him.
http://www.planetf1....en-I-don-t-care...
:laugh:
edit, i can't find the video of it yet. :(
Berk's prediction.
Vettel will be away to a 3-4 second lead after 2 or so laps, Webber will be down to 3rd or 4th after the second corner. He will hold it for a while, but shitty pit stops will relagate him down to seventh (son of a seventh son) midway through the race, he will fight back to fifth.
Sergio second, Kimi third.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
