  • Replies 5.5k
Posted Images
Jean-Eric Vergne has been slapped with a three-place grid penalty for impeding Bruno Senna during qualifying at Suzuka.
http://www.planetf1....ed-for-blocking
Kimi Raikkonen was at his best during a post-qualifying interview at the Suzuka circuit where he made his thoughts on the subject at hand quite clear.
The Lotus driver, who had made it through to Q3 in qualifying for the Japanese GP, came up short in the final minute when he lost control of his E20 at Spoon Curve and beached his car in the gravel.
As the chequered flag was waved the yellows were still out for Raikkonen's car meaning his rivals were forced to back off in that sector.
Asked what happened, Raikkonen said: "I spun."
Clearly...
Asked about the impact his yellows would have on the rest of the field, he said: "I don't care what happened to the others."
You have to love him.
http://www.planetf1....en-I-don-t-care...
:laugh:
edit, i can't find the video of it yet. :(
Berk's prediction.
Vettel will be away to a 3-4 second lead after 2 or so laps, Webber will be down to 3rd or 4th after the second corner. He will hold it for a while, but shitty pit stops will relagate him down to seventh (son of a seventh son) midway through the race, he will fight back to fifth.
Sergio second, Kimi third.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
