  • Replies 5.5k
Posted Images
I think Seb worked really hard for it in that race. Thats alot of pressure to overcome and I think he deserves it.
I'm not going to start an argument about who deserves it more, Alonso has driven a pig most of the season and its a very good effort to get that close.
Congrats to Kimi on being the only driver to finish every race this year. Consistency is right, just nail the performance next year ;)
Thats utter rubbish, and people are deluding themselves
Fernando has done well, but Massa has been more than a match for him since Japan. Out qualifying him on several occasions and having to hand his position over, or be forced to sit behind his teammate and not fight for poition
Thats hardly the sprint to the finish that wins you titles
Hey. People are saying vettel didn't deserve it. I disagree with that. I'm not even going to get into the Ferrari team tactics. That will start a whole other argument
Say what you like but 3 WDC at vettels age is amazing
Shocking
I, for one, and gobsmacked and cannot imagine a bunch of shit kicking, second rate, pathetic, sore losers would do something like that
I really cant
Oh how they'll celebrate with champagne and the respect of the paddock and wider motorsport community
Have you not seen any F1 over the past twenty years? It is how Ferrari operate. Say anything, do anything, manipulate everything.
It is not sport for them anyway, it is commerce. Plain and simple.
It'd be a shit way to win it, but really, if it does happen because he did pass under yellows, he should've been penalized in the race plain and simple. It's not a case of, well we missed it so let's just let it slide hey?
We're talking about hundreds of millions of dollars and a World championship in the highest level of motorsport, I'm sure you'd all be happy to let it slide if it was your money/championship.
Yes he would.
and realistically, rules are there for a reason.
It's even more damning because nothing was done about on the race weekend.
there is a precedent and therefore there must be consitency, sucks to have to do this sort of thing outside the racetrack but if you let one thing go where does it end ?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
