hey everyone, as above im wondering if anyone has done a swap between a rb25det and a rb26dett?
my series 1 r33 is running out of life and is slowly giving up after 220,000+ kms, still runs fine but will need to be rebuilt/swapped and i might aswell put a gtr engine in there instead.
so is it possible to do that and is it worth the hassle and $$$?
ive been searching thru sau forums but havent been able to find anything relating to this topic.
cheers aaron :cheers:
*hope i posted this in the correct thread*
Edited by buzz350
https://www.sau.com.au/forums/topic/384792-rb25det-rb26dett-swap/
im sure it has been done to death
the skyline r33 is 18yrs old surely there are dozens of people who have done this type of engine swap
its probably cheaper, easier and better to rebuild your current engine to a 2.6 litre stroke instead of removing your engine and buying a 2nd hand (possibly shagged/tired) rb26
you just need to check the reasons for ugprading
is it because you want more power / a newer engine
or is it because you really really want individual throttle bodies, air temp sensor control, twin turbos and non-vct?
if you just want engine refresh, more power and some new life rebuild your current one to a bigger capacity
cheers paul for the quick reply, ill have to talk this over with my mechanic to see if its viable etc.
and yes the reason is for a newer engine with more power without me having to tamper with it too much and not being able to have a car off the road.
but i guess an engine refresh wouldnt be that much more difficult.
im still wonderng if anyone has done it tho (aka if looms need to be changed or etc to make them run?)
Edited by buzz350
yeah its been done heaps both backyard style and workshops
for the specs read here
http://en.wikipedia.org/wiki/Nissan_RB_engine
but why would you take out your engine, buy a 2nd hand rb26 and fit that
it would not be worth the time and effort, for the power you'll get and the headaches/risks of a 2nd hand motor
if you were going to do it, it would have to a rebuilt rb26 so thats already a 10k cost (engine + rebuild)
this is why its far more reasonable to rebuild your engine, if you rebuild yours, you can pick what ever power you like
Im fairly sure that the general consensus is that a moded single turbs GTST is more exciting than your average twin turbo GTR.
Id stick to the RB25, if its shagged give it a refresh and soldier on. Use the money and heartache saved from the 26 swap to do some mods on the RB25.
if its more grunt that your after then build up/get built a 30 bottom end and chuck a reconditioned head on that . . . .if you do that while your car is still going then you MIGHT be able to swapem over on a weekend without the car being off the road too long (just need a tune after that tho)
^^Agree^^
if ur looking to do something a little different from the norm then yea you can put a 26 in it
like whats already been said, u run the risk of buying a stuffed 26 and u end up back to square one again
if ur lookin for a bit more power and fun then you would be far better off just gettin ur 25 built and spending some coin on some light mod ie.
turbo, injectors, ecu, intercooler, exhuast etc
alot less stuffing around to put an engine that was designed for ur engine bay back in as well
Not worth it as one the engine is alot more pricey than a rb25 and condtion wise you never know could go bang. You could probably buy 2 or 3 rb25 for the price of one rb26 and when modified and tuned if you choose the correct turbo setup I personally think you can get as good performance from the 25 you just cant rev as high. I would be going for a 25 rebuild and setting up a nice 200-300kw depending on what your after and choosing the right turbo for the job and youll have a reliable and fast car.
thanks guys for all the responses and opinions on the topic,
as a lot of you have said refurbing my engine would be the better option or buying another and building that up before doing a swap on the weekend.
its probably been covered, but whats the go with a rb25/30? pros cons, how are they built, run an aftermarket ecu etc?
again thanks for all the responses, has given me a new insight into my choices
Aaron
Another thing with the RB26, you need to mess around with sumps, as you can't just drop an RB26 in (with a AWD sump) attached to the the RB25 driveline.
wouldnt that be an easy enough swap by taking it off my old rb25 and replacing it onto the 26? or are there more issues involved when changng the sump over?
I guess with an adapter using the RB25 sump is do-able, just the pickup will require findling to get right, check (although it seems cutting off the front diff is a better option): http://www.skylinesaustralia.com/forums/topic/358496-sump-adapters-rb26-block-to-use-rwd-sump/
In regards to the 25/30 check the rb30 build page theres a good thread which goes through it all and has a document pretty much explaining everything that needs to be done. But yeah basically it is a great option to the price of a rb30 block is virtually free, youl get the added torque and response from the upped displacement. Ecu you can still just run the rb25 ecu you have.
this. if you do it bogan the whole conversion can be done for under $500
otherwise just drop another good condition 25 in. you can get bare long motors (all you need if you already have manifolds and loom etc) for under $500
Read the RB30 Pdf. For the price of a conversion to a tired RB26 you can get a forged RB30 built at your leisure and then just pull your engine and stick the head on the 30 and away you go. The extra torque and fresh engine will be a huge advance and if you want more power later you have the basis for an easy 300- 400kw (or more).
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
