that'd be right
Had a good perve of cars today :thumbsup:
Really need to remember to bring a Jacket next time
Also ffffuuuuuu Aaaaroonn!
lol @ the frustration of everyone else
  • Replies 230
Very fun day, was good to meet some more peeps and fuel my ongoing love of Nissans. It will make a comeback in my garage eventually.
Good job by the committee and thank you for the defensive driving course :)
Caption contest? :)
IMG_6423 by aaronactive.net, on Flickr
Guy: Honey, why can't I get a GT-R?
Girl: Because you'll want to come to these things all the time and we both know these guys are perving at my ass right now.
reverse that and makes more sense......
Girl: Honey, why can't I get a GT-R?
Guy: Because you'll want to come to these things all the time and we both know these guys are perving at my ass right now.
Need pics to confirm that her statement is correct
Mad shoes btw.
