Hi all,
Yesterday I installed an Apexi Power Intake into my R33 GTR. They replaced the dodgy wire mesh type fake alloy pods that were in it when I bought it.
I have noticed though that now the responsiveness has been diminished somewhat. I am assuming that this is because the airflow is more restricted with the Apexi (proper) pod filters rather than just wire mesh.
My car was slightly tuned when we lived in Perth, basically adjusted the timing slightly and removed the boost restrictor.
I am thinking I need to have it stuck on a dyno and the timing re-adjusted to suit the new intake system.
Can anyone give me an idea of the cost in Canberra to have someone do this? And any suggestions on where to take it would be appreciated. I am aware of Ultimate Tunes, which is 10 minutes up the road from me.
Cheers.
https://www.sau.com.au/forums/topic/384833-dyno-time-cost-in-act/
Just jump on the phone and call around.
Everyone will pretty much be willing to beat the other person.
Just get as many quotes as you can
Then go to one of the guys like listed ESP or Trojan and tell them what you were quoted.
See if they can beat that
Little off topic but I did this with my windscreen and saved myself $150 + got a new seal
Thats still true. How hard can it be to set up a dyno?
I've never asked them but given the size of their workshop maybe it's got to do with the lack of room? Although that then makes you wonder why they have it in the first place.
they just need to park a few more skylines outside to make room lol
I'll wanna dyno tune my can when put in the electronic boost control to get the settings just right too.... Need to call round and see what i can get for that....
Any one seen and good threads with advise for setting one up? Or any one have much experience at it?? Had no luck searching so far.
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
