I mentioned GTX2860's with oem .42 comp covers machined out with -5 rear housing and he said yeah he tried that, might be worth giving him a call yourself speak to Luke and ask him to confirm the supporting mods maybe.
I thought that would at least make 420.
My motor is being assembled very soon and I'm currently on the dash 9 bandwagon at the moment until I change my mind again lol
Edited by mr skidz
I thought everyone knew the gtx turbos don't come to life until 25psi?
Lots of people saying that but my GTX2867 is fine at 19psi and drastically out performed the GT2871
2.6
On a 2.6 you definitely need the right setup/method to be responsive :)
Daz has the right ingredients and method heheh!
By the way Daz I wasn't trying to be a smart arse :) I had good results from GTX2860's with a stroker setup, stock cams and BP98, but went shit when I put in cams and got another tuner to tune the setup when I headed north...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
