Paul, I read somewhere you were going to put smaller cams in it, is that still the plan ??
Interested in seeing the results....
Yeah mate. Thats the plan. A full blown HKS head with the "NAPREC" chamber mods, 1.5 mm OS valves and mines "252 @ 10.05mm" cams. That was the hardest decision to make out of the whole thing. It's still over there getting finished off. No real rush, it's coming close to 12 months since that head was started. Hopefully the cams will be big enough. Going by how far my intake cam is advanced at the moment and the curve is not nosing over they should be ok!
Paul when are we going back to Huntley. U have to beat all those evo's now.
How do ur gear ratio's feel with the new turbo setup?
Huntley. Funny you bring that up, I went for a drive and did it on Sunday (Nice and slow as it is a "public road"). The next Huntley is in early Feb. Bring it on. Lock it in :D.
Ratio's. It's alot more flexible now. I suppose thats what comes with more area under the curve. There is no need to rev the guts out of it. At Winton, alot of my changes were at 6 - 6,500 RPM just because I didn't need to rev it.
Eww K-Sport...the other ones are ok...the ones with the twin bolt bridge. I just hate the look, but they do seem to work well. But would still rather 6 pot Alcons on 380x35mm rotors :)
  • Like 1
sure, but you are a brake whore :P
I've had perfect results with these, even at targa and long races. I've bought 3 sets now for different cars (1 and 2 bolt bridges) and had no problem since the fit/clearance problems on the first set 5+ years ago.
Thanks for the thread. A couple questions:
-Is the ross kit available to the public in d-jetro form yet? If so, is pricing public knowledge?
-Are you able to have your tuner comment on the ross kit? I'm curious just how much more aggressive he can be with the tuning.
-Did you consider any other options for the sync issue?
PM R32 TT, he did the crank trigger mod on it's own. I don't think he found he could add any more timing...
Re pricing, call Ross. They're doing it in kit form which includes everything from the balancer to the crank and cam triggers, optical sensors etc etc which is around the 2k mark.
yea the black one that has a f@uk load of dust and shit on it lol... the blue 32 with the flared guards makes mine look like a dump haha
Did u manage to get a look at the turbo and manifold set up i have?... theres alot of work to be done because of how everything sits so i wont be seeing it for a while :unsure:
i pretty much only bought it because yavuz recommended it so if he thinks its worth it then he has me convinced
Hows does the power delivery feel? smoother or cant really notice it?
I was there a couple weeks ago i did see your 33 apart from the dust it is a tidy car!! but that blue 32 worship.gif gave me a stiffy!!w00t.gif
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
