Hokay,
lend my your ears eyes,
New car is down on compression on the number 5 jam pot, but I don't know why!?!?!?! it came up at 88psi when the rest were 150-160
The car has dodgy valve stem seals, so blows some smoke after idling for a while, but that is unrelated to the lack of compression. (or is it?)
I initially thought the rings were shot, but it doesn't blow smoke under load and the motor is very quiet, has very minimal blow-by and feels quite strong and smooth, idles smoothly yadda yadda yadda.
It is a dead stock 1JZ with a cat back, standard boost factory intercooler etc.
Now to my theory, is it at all possible that the leaky stem seals have gummed up the back of a valve which is causing it not to close/seal properly? I'm sure it is possible, but I have never seen/heard of it in person.
Now when my RB25 chewed up and spat out a ring, the smoke would increase with revs/load as well as showing obvious pulsing blow-by.
I'm going to try and borrow another comp tester and squirt some oil in the bore to double check (I didn't have anything handy this morning)
But like I said, no smoke under load, to me it doesnt make sense.
So I hope you can help too a) put my mind at ease and b) save me from having to buy a new motor
Cheers
A
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/
  • Replies 52
Posted Images
So, easiest way would be pressurize the cylinder and listen in both the intake manifold and the tail pipe for the hissing?
I would but my air compressor is at my old mans house 1100ks away lol
Titan - yeah, only smokes if its idling for a while, if you blip the throttle after idling you get a big puff of blue oily smoke.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6139947
smoke sounds like a turbo oil seal (early). a little leaks down the dump while off, then starts to burn out once hot. it can seal up under boost depending on where it is farked so no smoke then.
nfi on the compression.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140059
I had considered that, but it the smoke is too instant after starting cold, and I'll be f**ked if I am pulling 1J turbos off ever again! lol
I will pull the cooler piping off tomorrow and have a squiz, but 20 years of crank case gasses being sucked into the intake pipe means it will be oily
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140068
i was goin to say just before mine let go it would blow blue smoke on start up and miss a bit...then as it got warmer the smoke would disappear and the miss would go away as the rings sealed better
if urs isnt missing at start up then its not the same case as mine...
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140355
Valve stem seals would explain the smoke / burning oil on start up,
the burning oil may have glazed the bores and your leaking compression past the compression rings, preventing a proper seal with the glazed bores, but your oil control rings are still sealing to explain why your not consistently burning oil
leak down test / wet comp test will help
May also be leaking passed the head gasket giving you low comp
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140375
There is no use over-complicating the issue. It's practically a dead stock 1JZ....the likelihood of glazed bores is so remote, it is literally the last thing you would consider. That and the fact it would smoke all the time if that were the case.
You definitely need to do a leakdown test before you can make any assumptions. It could even be a worn valve guide causing the valve to seat incorrectly AND make the stem seals leak - also not likely on a single cylinder
Remember when you are doing the test to have it at TDC Comp on that cylinder
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140650
So the plot thickens.....
These are the same plugs that were a little oily the other day...cleaned them up and put them back in.
Pulled them out again today...
:unsure: looks a lot like rust to me
compare these to one from the Soarer
The orange plugs are BRK6EP's
cyl 1 on the left and 6 on the right
the plug from the soarer is a BKR6E
found my little high power torch so had a look down the plug holes, piston crowns are dry, and also have a slight brown/orange tinge, No sign of any oil in #5, they all match evenly.
So I am thinking that Duncan is correct in saying that it is a turbo seal, Causing my smokey exhaust
Doesnt explain the lack of comp in #5, but I may have muffed the test, there was a bit of crap around the #5 plug hole that may have caused the tester to leak >_<
The car doesnt seem to use any water, but I havent owned it long enough to say for sure, the oil is about 400ks old and looks brand new, so I think that if it was rings the oil would be a lot darker
Any more ideas
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6144324
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
