Hey ryan.
I don't think I've taken photos of the undercar surges.
I have one that is R33 specific, r32 ones don't fit.
Door trims are not a problem either but I only make those to suit the vehicle installation included in the price. The doors require some modifications to fit them neatly on the R33 which I rather do myself.
Hey ryan.
Sounds the money I have some doors here I could drop down if that would work.
When you have five call me or pm me a price for each part, next year will be fine bud if you are enjoying your break.
Cheers
Yeah I run one under the car that looks stragely similar. It's the only sensible way to do it....why would you want fuel lines running around the boot, especically in a targa car where you might be throwing spare wheels/tools/etc around in there. Dirt cheap because you just run a standard or 040 or similar pump in the tank and an 044 or 023 under the car.
The only thing I forgot is you still run out of fuel with a surge tank if you empy the fuel tank :O. It made it much further without surging though
There is a few options for the under car surge tanks.
1x pump
2x pump
1x weldon pump (far better than running 3x 044's, better than 2x 044's as well but more expensive)
All types are offered with -6 or -8an inlet/outlet fittings or 5/16ths welded on barb fittings ( the most common way to do it)
Also if you want one you'll also need to determine how much of the fittings you want me to supply with it.
The weld on tank fittings are included
-12AN couplings, pump inlet and outlet fittings are extra.
Ive done a few R33's but never made a jig to reproduce the mounting tabs.
So ill need to borrow an R33 for a couple of days to mount a tank and jig it up for latter reproductions.
Sounds good I will give Neil a buz tomorrow, is Zebra's old car still lying around Brad?
I already have one new 044 that I was going to put in the boot so I will use that. I like Fatz tank and set up I would just want the same as his but with the clamp for the second allready welded on an a cap on the other outlet. I will need the fittings for the tank to the pump and the outlet of the pump to the hose fitting.
I am also keen to talk to you about some door stuff and a breather tank set up for 26 covers on my engine.
Cheers
We only need to be told once... :P
I've still got some shit to sort out on my car quickly first before it comes back anyway, I'll give you a ring after new year and we can work out when you want mine back.
Still need to mod my exhaust manifolds... Stupid freaking bunnings for not having the right dremel gear... :(
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
