Hmm...will get one sooner or later. Need to chat as needs to be modded to suit rwd and need to understand if it will clear my swaybars and whats going on with baffles and volume. I need to understand if/why you need 8 or 9L in a rwd car. Surely if you are keeping oil temps around 100deg C and you are not getting surge then do I need the headaches of uber pricey oil changes :)
Martin at the moment im waiting for a batch of the fittings your wanting to be machined. Unfortunatly I cant quote you on a fitting that I dont know the cost of as yet.
Im hoping to have them this week and will be sure to let you know the cost.
Ah fair enough mate, no problem. Sorry, I misunderstood your last PM.
Cheers,
Martin.
There is a few bars I'd rather it have but cost is always the issue.
Ideally it would have had a X in the roof section, door jam drop bars, two or 3 fire wall bars and some gussets in the X intersections.
Now I understand.
Yeah I've done plenty of r&d with various upright setups for the GTR.
They are not the type of thing that I sell to anyone who I dont permanantly prepare the car for though. They are not a miracle cure for the GTR's issues. It still requires alot of setup work to become beneficial.
From experience with selling them to people, if they are installed and setup properly they work, if not the car goes backwards.
It's not worth selling them to people to have them complain they don't work, which is how it was heading.
Now I understand.
Mighty impressed with all the custom work. Would be interested in pricing for the R33 GTR under car surge tank with eitther the twin 044's or the single Weldon pump for pricing comparisons
Keep up the good work :thumbsup:
Sorted Novak.
Sorry if some guys are waiting on replies. I'm getting married this weekend and have been flat out trying to finalize work and wedding things, so unfortunately some quotes and replies are taking time.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
