Brad,
I have held off on posting, but I need to post at this time. I hope to receive a response.
Please provide me with an update of your proposed soloution to handle the "Returned undercarrariage BCNR33 GT-R fuel surge tank", "damaged BCNR33 GT-R combo blowby/washer tank" and "two missing filters for BCNR33 GT-R combo blowby/washer tanks".
Respectfully,
David
okay, in addition to my post from the 10th of November, I have sent Brad an email too. will see on a response
Ive read this thread and cant hold back.
You guys are suckers.
Is it because your lazy, or too afraid to DIY?
Go buy yourself a welder, costs less than what your spending with this loser.
Buy something useful and keep it.
Thats why i dont let many people touch my car, its expensive, and most of them are going to do a shit job anyway.
:mrt:
Pity the FOOLS!
:mrt:
Pity the FOOLS!
But in your build list there are clearly parts that you BOUGHT! :O
Shouldn't you have set up a factory with multi-axis milling machines, lathes, chroming and anodising facilities and made you OWN coilovers and suspension arms?
I put it to you; that YOU are the sucker.
It may also come as a surprise to know that most people can't knock up a CAMS approved rollcage in their garage, and I'd bet dollars to donuts; neither can you. :thumbsup:
But you keep on insulting people that supported a local business... :rolleyes:
  • Like 3
:mrt:
Pity the FOOLS!
Some jobs are better left to the professions rather than an amateur with a $300 welder...
Edited by [200]
  • Like 1
Hey leave the guy alone.
He's got a welder, compressor, rattle gun, torque wrench, compression tester and jump pack. It's a fully kitted race fab / workshop.
Having made that dig, there are a lot of jobs you can do yourself with decent tools and a bit of nous (although some people should never be let within 10m of a spanner). Most important thing is to know (and acknowledge) your limits.
four days since my post here, three days since email to Brad, and here we are...
anyone else?
Edited by JadeGTR
i got one email back
said he is working on teh adaptors and can pay installments
bank details were sent
will let everyone know if i see anything or get a reply
^^ Keen to know what happens mate.
Brad said that my car will be finished in 3-4 weeks. Can you remind me of this post Fatz ?
:mrt:
Pity the FOOLS!
all the gear no idea lol
