So I picked up a set of gtr wheels And wanting to put tyres on them iv seen 205 55 on them but every tyre shop I go to say its impossible to fit and it won't stay on :s So if anyone can confirm that 205 fit :) or recommend me to a tyre shop in Melbourne :)
Thanks
https://www.sau.com.au/forums/topic/385119-r32-gtr-wheels-tyres/
205/55 on an 8" rim will not be stretched, not in the slightest. At best it may sit flat. 225/50R16 is the size the GT-R's ran, so you can stick with that but 205/55 would be fine too. It would not fall off or something crazy.
It won't be stretched like hellaflush... But its outside the legal width for 8" rims.
205/55R16
5.5-7.5
Source: http://customwheelsm...heelwidth1.html
Edited by 10 4
That's exactly what I wanted to do!! But since it's illegal :(
Pfft! What isn't technically illegal with modifying a car, too low, too loud, blah blah blah. You will be fine, they are 16's nobody will be checking out the tyre sizes to see if they are staggered.
Go for it mate.
Sell the tyres and buy some proper ones. 235 or 245 would be better.
You can't really buy a 235 or 245 wide tyre to fit an R32 GTR wheel / car. The closest you would find (even this would be difficult to find) is 245/35R16 which is way too thin.
That's a very tall tyre to run :huh:
Its the only aspect available in the 245 16" sizes available AFAIK. 16 " tyres have no love anymore, I was looking at getting some R32 GTR rims until I realised that you have a very limited amount of choice, still if you got a quality tyre the side walls should be stiff enough, not good for circuit work but good for a daily and good for drags.
Motorsport > http://www.tirerack....=45&diameter=16 The VictoRacer V700 are a nice tyre and a nice price for a sticky 16" semi.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
