yeah, im very grateful they are going to have a look at it. I would have been in a bit of strife if they werent going to have a look! Not alot to report on, just ordered a new balancer today, got a ross metal jacket. Trying to organise some time off so i can get chris from audio express to come up and get some alarm stuff done(in between sinking bulk piss and the possibility of fishing).
  • 1 month later...
well, got the head back from jacobsens today, been away for a while working :( Cant seem to get away from work, its doing my head in. Everytime i have a quiet week something goes wrong, like todays effort, quiet day, only job on for our franna crane, on the way there it lunches the transfer case, now there is an easy 36k gone :( took out the emergency steer pump, 4 uni's, the torque mounts for the box and the centre air tank! I so need a bloody holiday
  • 4 weeks later...
well, water pump showed up on thursday, still looking for sump baffles though. Starting to look like a complete engine again! For those interested, i found a waterpump locally at REPCO, it was to suit an R31 skyline, but here is the kicker, make sure you get the GMB or REPCO branded pumps. I pulled one to bits and checked everything out, they are exactly the same as the stock one i have, down to the seals and bearings! i vernier'd the pump rotor, same as a stock pump as well, same number of blades, same with and length as well. Ill take a snap or 2 and post it later on when i get off my a$$ as i have some fishing photos to upload as well today
I found the same thing when I bought my Bursons waterpump at less than half the cost of OEM.. 30K km's later with drift days and tracking it not a problem.
If you are after a good sump baffle my good friend Paul (Piggaz on sau) has a JUN baffle with trap doors etc out of his Tomei 2.8 for sale. see here: http://www.skylinesaustralia.com/forums/topic/395875-gtr-parts/page__p__6289057__hl__jun+sump+baffle__fromsearch__1#entry6289057
I would of bought it myself but i wont be pulling my sump off anytime soon. Tell him Dave sent you and he might knock a bit off the price :thumbsup:
  • 1 month later...
well, its been a while, work has had a hold of me pretty firmly lately. The top end is assembled, bottom end assembled and its just waiting on a baffle and the sump goes on. The turbo looks a little bit BFOT but hey, i wanted the kick in the nuts of it so thats what i get lol
A few quick snaps of it as it site until tomorrow(obviously it will be under wraps so no crap gets in there lol)
Bottom end all assembled
Frontal view of said donkey
Hot side derp
Cold side derp
and the sneaky crankshaft hiding whats inside....
Sump baffles arrived today so ill be doing an install and review writeup on them tonight
Cheers guys and enjoy
sump is on. Now to get to the nitty gritty. Looking at ignition options and injector choices. Havnt gone a balancer yet as i dont know if it will warrant a trigger setup or not. Still a little way to go
Looks like the head will be delivered to UE today so I'll be out there this arvo. If so I'll give you a buzz tonight.
Thought id throw up some pictures of the sump baffles. They are really a Bolt In affait. It doesnt get much easier than the Nismo baffles.
As you can see, they use the factory hardware for mounting and are one piece unlike the tomei baffle. Perfect fitment except for a slightly bent corner due to bieng mishandles by Auspost, but easily ficed by gently bending it back
Enjoy ;)
  • 1 month later...
well, progress has been slow due to work commitments but i have a list of parts to fit now. I ended up going to an ati balancer, id2000's, nismo engine and transmission mounts, hks front mount, hard pipes and i need to figure out the best way to mount the map sensor to the plenum for the vi-pec
It was pretty bloody good deano, took minimal to balance it all and i can pretty safely say it wasnt really needed. I was warned about an oil squirter issue in some engine blocks but i did not have this issue.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
