hey does anyone know where i can find another fitting for the RB25 NEO water outlet to radiator (on the intake manifold) it has corroded and im struggling to find a new one.
i found a picture of what im talking about (this guy is holding a new one)
  • 3 months later...
You can take the manifold off and get a pipe welded in place (any ally fabricator)and a bead welded on the end to stop the hoses blowing off, i did this with my 20DET to get rid of the adaptor that steps the hose to a smaller diameter, didnt cost much and it works fine
  • 4 weeks later...
That part looks like it is supposed to corrode - that is - be the "sacrificial anode" in the electric circuit created by the coolant. In older cars i've worked on the thermostat housing typically performed this function. If you want to understand why, google galvanic corrosion.
tl:dr - only use the replacement Nissan part so that the head and/or block dont start corroding.
http://www.300zx.com...ylineengine.htm
UAS Chrome Molly Upper Radiator Outlet Intake Manifold
Replaces often rusty factory one.
PRICE: $65
This is what mine looked like
Holy crap! It looks like tap water has been used in that cooling system.
  • 1 year later...
  • 3 months later...
  • 1 year later...
Mine is corroded but not so bad I have to replace it just yet, but when I looked I was going to cut it way using a dremel and a tungsten bit. So slot it and then collapse it. Not sure if thats the best method but reckoned it could work. Be careful not to hit the alloy though, don't really want to scuff it too much.
Pretty sure you could then mike it up and get an exhaust place to make up a new one, if you only have to do it every 15-20 years trhen I don't see a big problem.
I had that issue about 2 years ago, I thought I posted here but I'll chime in Now
I took it to a mechanic and he said he'd seen it heaps, he said he would use a chisel and then collapse it like the other person above has said, then he had an exhaust place make a piece and roll a lip in it
I didn't want to have half a go and do something wrong and then have to tow it So let him do it for me
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
