It's no different that the stock set up in that regard though.
If your venting the catch can then you will have air entering the engine the engine that is unmetered.
Best solution when removing PCV is to run both rocker cover breathers to a sealed catch can and then a single line back to the inlet pipe.
That's what I thought but it looks like It's creating enough pressure to blow the front seal?
IF you've pumped the head full of oil then the there is no path for the blowby to release pressure from the sump - usually this is when dipstick pops. Not sure why your front seal is failing though. How hard is it to remove your dipstik?
Anyway the fix will most likely reduce the amount of oil in the head - ie smaller restrictors.
That is the best setup when keeping the PCV...
If removing the PCV best to vent atmo...
I wouldnt say that the dipstick is stuck or hard to remove at all.
I don't really care about keeping the PVC or not - I just thought it would be better if I removed it.
Is there any benefit to keeping the PVC and most of the hoses from the factory, but install the catch can beetween the exhaust-side rocker cover and the inlet before he turbo?
I guess the immediate other option would be to remove it altogether?
Er if the catch can is venting to atmo then it is venting to atmo and not the intake!
That is the set up which is being criticised for sending unmetered air into the engine. I was saying that it does the same thing as the OEM set up except the PCV on the intake cam cover in blocked and the oil drops out in the can. If it send umetered air into the intake then so does the OEM set up!
Well you still get oily air being sucked in off boost so it is kind of half-arsed solution.
What? If the catch can is plumbed back into the intake AND venting to atmosphere then you will be drawing unmetered air in through the vent and into the system. If everything is plumbed in, you can't get any unmetered air going in. Where do you think this air is coming from??
Where was I advocating venting to air AND plumbing back into the intake?
Maybe I got this wrong but the solution where you block the PCV valve then keep the other side plumbed into the intake via a catch can (which is closed), was criticised as allowing unmetered air into the system and someone said you have to just let the catch can vent to atmo or it screws everything up? Can't be arsed going over the thread to find what was said.
See, I was thinking thy the sucking pressure that the PVC gives off-boost would be offset by the draw from the turbo (not necessarily pressurized) when plumbed back before the turbo.
I have seen pictures above which keep the PVC by having a t-piece near the PVC with one side going to the rocket cover and the other going to the catch can. I am guessing that this would be inefficient as the PVC valve would draw some air from the can rather than drawing all it's air (and vapor from the rocker cover)?
You didn't, someone else did.
I don't understand where you think this air is coming from? The stock setup is a sealed system. There is no unmetered air in the system.
nope, at idle the intake pipe has very little suction, if you put a gauge on it you probably wouldnt get any vacuum, whereas the plenum has heaps due to the throttle body being shut. obviously the closer you get to 0 vacuum in the plenum the less it would draw through from the intake side, until the pcv shuts as soon as you hit boost then it starts flowing the other way if theres any blowby.
@hanaldo, he doesnt think theres any unmetered air coming in, someone else implied that and has confused you :thumbsup:
has anyone noticed on the exhaust side of the head (RB25-RB26)
there is a threaded plug that can also be used asa drain back to the sump similar to the rear head drain.
depending the what exhaust manifold you have on there it may of may not be accesible. on my 2530 there is plenty of room to do this. just need to get around to finally doing it.
Hi this is how mine is setup works great large hoses from r/covers and smaller hose to turbo inlet catch can full of coarse stainless steel wool and pvc stock
Back to what i believe was part of the original question and what i would like to know, is it better to use bigger breather hoses to get more out faster than standard, i have mine plumbed up in the factory configuration but i use a line from the cam cover that does not have a restrictor in it like the factory line does, it then runs through a catch can filled with stainless steel wool as a filter and then back to the intake pipe, is this better/worse/no different to have the restrictor in the line?
I used to have my breathers vented to Atmo with the PCV blocked but after a while i was getting blowby and plumes of smoke out the exhaust at idle, and taking off, and backing off.
I was advised to put the PCV back to stock, and have never seen another cloud of smoke since.
The setup i have now is, Stock PCV, Breathers vented to Atmo VIA a catch can, and no turbo inlet pipe.
As someone mentioned, i just dont think the turbo inlet has enough vacuum at idle to sufficiently draw the vapours out of the head, if it did then the PCV wouldnt be there factory.
  • 10 years later...
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
