My car sometimes, not all the times, hits about 500rpm when clutching in. It doesn't sound like its going to stall but it doesn't sound like it should be doing it. I have a fair bit of bolt on mods with the PFC ECU. Sometimes when coming to a stop(and it makes no difference, off boost, light throttle etc) the revs come to about 500rpm and the car kicks back up and idles fine. Ive cleaned the AAC. Ive removed fuel from the cells it hits in the first column of the pfc but didn't make a difference. Its going into the first column then into the higher load cells. Something is telling the car there is a load on the engine and it kind of f**ks around a little...
Also, now don't anyone give me shit for it, if I want to remove my BOV, how do you tune out the symptoms of running no BOV? I know alot of cars who have no BOV with nice deep flutters and there car doesn't stall. My old skyline would switch off instantly even on a free idle rev and flutter. Is it about removing fuel or giving it fuel?
https://www.sau.com.au/forums/topic/387111-how-do-you-tune-out-flopping-rpm/
There is no way to tune a PFC around maf reverse caused from running no bypass valve. All you will be doing is fudging one section of the map to stop overfilling of another section of the map.
Ie you may help the idle sag but create a lean spot once on throttle. If you want your car to be in a proper state of tune put the bypass valve back on the car and get over it.
But Ive seen and heard of a fair few skylines running power FC with atmo bov and even with a blocked BOV and some don't have the issue...
Gay piece of arse AFM.
None the less though I still get the dip in RPM WITH the BOV fitted. Like I said in the OP, I don't even need to be on any boost(all vacuum) and it still does it. Just now I was driving home 50km/h in third. I clutch in to stop at the lights and they dip to 500rpm then jump back up, it just gets worse with the BOV gone.
Edited by SargeRX8
IAC and AAC are the same thing just different names.
No, not true. IAC is the one on the back of the plenum that the ECU controls the idle speed with. The AAC is the Auxiliary Air Control which is the heated thermostatic valve hidden under the plenum that is open when cold and closed when hot and allows a lot of extra air in to raise the cold idle.
The only one that matters in this instance is the IAC, but if he's cleaned it and it still fluffs around then it is probably a tuning issue as per others above.
I cleaned the aac as per the diy. Is that cleaning the iac too? Afaik the aac lets the engine breath more air when you use things like air con, the brakes, power steering etc.
Isn't that thermostat the csv, cold start valve which is the one under the plenum?
Edited by SargeRX8
Ah i see now. So the AAC is what i was calling the cold start part of the system and the IAC is the Idle control. i always knew that's what the IAC did but people always throw AAC around and gets confusing.
Yeah that's fair enough then. at least that clears that up
I changed my FC/1 and FC/2 settings and mine is fine now. used to dip a bit when clutching in and IAC has already been cleaned. set them at 1500 as suggested
Edited by 89CAL
good to see your being as helpful *cough*condescending*cough* as ever mafia.....
Will adjust those sells by a few degrees, +5 should be fine in each cell right?
depends what they are at the moment. i wouldnt go any further than 20-25 degrees in n01 as any more is likely to go backwards and have the same effect as less timing. unless your timing in these cells is really low for some reason this will just help to mask whatevers really causing it. its sounding more and more like a sticky iac/aac
its abit hit and miss as that rpm range canot be acuratly "dynoed" i find wacking in some timing and similar fueling as at idle seems to help. also having a blanket 20 odd degrees around the idle area seems to smoth out a unstable idle. bigger afm,s and non return bov's do make it harder.
also raising the decel fuel cut to around 2k helps aswell. on our race car it has no idle control at all. and used to hunt real bad after giving a rev. when i turned off the decel cut it was perfect.
The decel fuel cut not cutting out soon enough could be the issue.
20 deg of timing around the idle is a fair bit. I run 16° at idle, 12° at 800rpm. Also 13.8 AFR 1200rpm and below. Good for clutch out at idle in traffic - crawl.
the only suggestion i have is find someone with datalogit, copy your tune
get the engine setup correctly, base timing, remove your bov or fit it (how ever you like), check the aac valve, check idle air control, check for basic vac leaks etc
then DATA INIT
perform self idle adjust as per powerfc-faq
and let iet idle for 30 minutes (dont drive or f**k around, just let it idle as per instructions)
then confirm you have good idle and stable de-accel
ie go for a fang around the block and confirm its OK
then "write" your previous tune over the top
if you dont have access to datalogit its a bit painful to do it manually
ie pay someone beer to copy your tune
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
